Page 19 of 66 FirstFirst ... 9141516171819202122232429 ... LastLast
Results 271 to 285 of 982
  1. #271
    Feb 2016
    portugal
    Default thanks...
    Quote Originally Posted by FxShaw View Post
    Yes... I have many times & after done flashing you would have to replace HC125 to HC125M as marked in step 4..Other wise it will never actually write to anything.
    Adding Carprog Antenna Fix.. Thanks to PierreTheron for the Info.
    CarProg 8.21 included with lib, exe, firmware with no activation needed. Extract 4 zip and then open zip file and extract.
    Lets not forget that there is a Thanks & Rep button, Feel free to use it .
    just what i need
  2. #272
    3inferno3's Avatar
    Nov 2014
    Europe
    Hi lats. Any problems with my favorite HC08 2J74Y? Did you try read it in circuit?? and isn't work? better if you unsolder it like I do. It is much faster to program it on QFP64 table. like in picture..and did you try read secured ews 2 with mask 2D47J? TRY IT.look how nice clones work with any motorola HC08 look on airbag module with mask HC08-0J66D clone read it in circuit don't forget swap diode SS14 with this solution you can work without extended power cheers lats 20170322354.jpg20170322351.jpg20170322350.jpg20170316336.jpg20170425389.jpg
  3. #273
    Hi 3inferno3. I don't know what is the "SS14 diode" you are talking about.
    http://www.digital-kaos.co.uk/forums...=1#post3011048
    Could you please mark in my pcb pictures, the diode? It will be highly appreciated. Thanks
  4. #274
    3inferno3's Avatar
    Nov 2014
    Europe
  5. The Following User Says Thank You to 3inferno3 For This Useful Post:
    j0anita (4th May, 2017)
  6. #275
    Thanks a lot for the picture.
  7. #276
    3inferno3's Avatar
    Nov 2014
    Europe
    No problem u can ask for more i I can help you got it
  8. The Following User Says Thank You to 3inferno3 For This Useful Post:
    FxShaw (4th May, 2017)
  9. #277
    Dec 2010
    Default Carprog china clone - Cables color codes and pinouts
    Hello all,
    Because I have a china clone carprog, with different colors on adapter cables that the original cables, it was very difficult for me to figure out which color where should be connected. Of course, no 100% solution found on internet. For those which have the same problem, with colors on china adapter cables, and for those which are looking for Carprog DB-25 pinout, A4 EEPROM adapter pinout and A6 Clip adapter pinout I will post my work here. I hope this will be useful for someone.
    Tags: carprog pinout, carprog db-25 pinout, carprog A6 pinout, Carprog A4 pinout, carprog connector pinout, carprog 93c86, carprog 95xxx
  10. The Following 17 Users Say Thank You to McCasian For This Useful Post:
    al70 (23rd March, 2019), amor89 (30th October, 2017), aruncius87 (13th January, 2019), cudzy (27th September, 2022), deteli (30th March, 2018), ecufix (27th February, 2020), FxShaw (9th May, 2017), hruzicka (19th January, 2018), KangaroSalesman (21st April, 2020), markgo40 (17th October, 2018), martinracing (14th November, 2017), motocarlos (11th January, 2021), nihadbeg (27th April, 2019), Patrone (4th June, 2017), satalightmad (24th June, 2017), Tigmaker (10th February, 2018), trybek89 (1st August, 2022)
  11. #278
    Hi guys, i am new to all this and learning. i have a carprog clone, with s/n 081105CAR001773I. I found what mods need to be done to the interface and cables. will this enable me to read vw clusters and code new clusters? if , is there a way to make my carprog do it? thanks in advance.
  12. #279
    3inferno3's Avatar
    Nov 2014
    Europe
    Hi mate..what kind of cluster You want swap?? on can bus or k-line? Vw group?
  13. #280
    I'm trying to flash my unit. JTAG Led red/green is on and i get: ERROR: Could not find supported CPU core on JTAG chain
    All connections are ok, at88 pin lift up. Any idea why? Thanks
  14. #281
    Aug 2008
    mcu not erased or bad connections
  15. #282
    I would like to swap mk6 cluster in mk5 car.
  16. #283
    Aug 2015
    BEHIND YOU
    is there any solution to read mazda infenion XC2361 srs with lastet software using clone?
    read by obd or in bench
    IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
  17. #284
    Feb 2014
    Hi guys,
    I wonder if you know the differences between the carprog SE53-B and the carprog SE53-BF.
    What is the best for v8.21 online?
    I do not know if the SE52-BF version is for the new software v10.05?
    thank you in advance
    Vash83
  18. #285
    Canada
    i am having issues with carprog (orig) it won't read 93c56, 93c66, 93c76 .... everything else is working fine,,
    read with x-prog its works,, carprotool works,,
    any ideas hardware or software problem,,,
    thanx
    If i helped you please press thanx
