Page 25 of 66 FirstFirst ... 15202122232425262728293035 ... LastLast
Results 361 to 375 of 982
  1. #361
    Junior Member stvesc3's Avatar
    Oct 2017
    your adapter its diferent
  2. #362
    Oct 2017
    hello,
    can not download carprog 8.21 from # 4 not completely, only file 2 + 3.
    can someone send me file 1 + 4 or the complete program?
    Thank you
  3. #363
    Portugal
    hello.
    orrect me if I am wrong, I to change the version I have to change the firmware right, I see that I have switch cable components for it to work fine?
    the version I have is 9.31 clone and the lib file. 081105caroo1773l but it is not working all its functions.
    thank you
  4. #364
    Portugal
    Quote Originally Posted by 3inferno3 View Post
    Here is soft and firmware.....download and program it http://www.digital-kaos.co.uk/forums...ything-Carprog
    correct me if I am wrong, I to change the version I have to change the firmware right, I see that I have switch cable components for it to work fine?
    thank you
  5. #365
    Oct 2015
    carprog clone can do honda air bag reset tms320?i follow diagram also cannot clear crash...
  6. The Following User Says Thank You to khching2003 For This Useful Post:
    gonzcaal (24th October, 2017)
  7. #366
    Jul 2016
    USA
    need help:
    for clone I have 7.8 and 9.3 clone carprog software versions
    trying to do 2013 Nissan Altima with infineon XC2336B-40F mcu,
    with clone carprog,
    when trying to read get error: "fail to connect to remote server"
    (I also have one real caprprog but fir that one I didnt buy any software yet, only adapters A1 multi and GM )
  8. #367
    Oct 2017
    Finland
    Hello.
    I'm confused with my china clone 8.21. I have red many things about fixing carprog clones but I haven't found a good solution to my problem. Last mod I made was changing HCT125D's to Texas Ins. HC125M. Original ones where Phillips 74HCT125D. After this done U11 got super hot and I disconnected usb.. Can somebody post pictures what to do on board please.. New 125's where checked by the supplier that they are correct type and I soldered them on just like the old ones where in the board..
    What's going on with this thing, any Ideas??
  9. #368
    Oct 2017
    I would like to connect carprog with delphi delco hsfi 2.1 ecu (opel astra g - z14xe) on the table . Do i have to use the A15 cable ? Does the A15 cable has electronics inside or is just a connector with wires ? Is there a way to find the A1 adaptor schematics ?
  10. #369
    Trstenik - Thun
  11. The Following User Says Thank You to mikroel For This Useful Post:
    ecufix (16th April, 2020)
  12. #370
    otojm's Avatar
    Feb 2012
    Kepler 22b
    hi, my carprog have a CAN communication problem it dosn't communicate with any device ,the K-line communication is good
    i have update my adapter A1 (all changed resistor,capacitor, mcp...) but still no result ?? any help please,thanks...
  13. #371
    Aug 2008
    LV
    i have see v10.05 china copy, what is difference from old one ?
  14. #372
    Jul 2016
    USA
    Sorry if this was asked before or dumb question but I can’t find answere anywhere.
    (I have original carprog and clone carprog but mostly use original because clone works very bad.)
    What is “ carprog units “ ? Every time I start carprog software and read eeprom I get “.. number of units left connect to synchronize “ and eveytime the number is less and less.
  15. #373
    Home
    Counter left...
    Keep in mind, English is not my native language.
  16. #374
    Jul 2012
    brazil
    hello friend after I programmed the flash of my carprog, he le km more do not write
    can you help me?
  17. #375
    Kocta's Avatar
    Mar 2017
    Garage in the Czech Republic
    Carprog vs Motorola HC 12 mask 0K75F
    Press Thanks and Reputation
