can you post link for 8.21 dump ?
[QUOTE=dadal;3207266]http://www.digital-kaos.co.uk/forums...=1#post3170582
Press Thanks and Reputation
I am Search for Atmel dump not SW![]()
Domi (5th February, 2018)
Hello, I have a little problem with CP. On the box from seller is sticker v10.05 but probably is 4.01 really . I'm install software 9.31 with 081105CAR001773I.lib. Many funkctions like ECU VAg is n/a. ECU pin from Opel Kline is working but when I try add card in Megane II 2004 show me a box: attempt 1,2,3... end connection error. I have a1 adater with cables between obd to a1 board. Every capacitors and resistors is ok. Voltage regulator work ok and take 5v to mcp. What kind is it problem ? Best regards from Poland
I'm try HW test and CP on a9 and power supply is OK, a1 in 97' VW kline OK, and d1 "no responcy from unit"
Photos #1
Photos inside #2
https://m.youtube.com/watch?v=vYpoRLvIPJM
Try this procedure
tomas1991 (5th February, 2018)
I'm doing the same procedure but when I'm put card , click read immo , cp show a dialog box: remove card and press start. I'm remove card and press start button on the car console then CP show this triple attempt and the next show error. Without remove card while dialog box showing is the same error.
Reads the CP-PIN?
no, CP don't read pin, when I'm click "read immo" is 3 attempt to connect and connection error
Hi, replace these parts
http://codecard.eu/carprog/carprog-r.../prod_566.html
ok, but better replacement with 74hc or 74hct to readin' 94cxx memory ?
4x MM74HC125M
Hi everybody. Can somebody confirm its the right ones for replacment?
https://uk.rs-online.com/mobile/p/bu...tions/6630020/
