Press Thanks and Reputation
I replaced kit with 74hct125m, mcp, tantal capacitors and quartz but is the same problem... Anyone have a idea? I checked on 4.01 soft version too - the same as firmware in atmel - but don't help. I try with and without 102 smd resistor in a1 pcb between can l and can h- the same. KF 50 ? Maybe 4.01 fw dont have CAN funxtions? A1 pass the test plugged in car and without pluged into OBD.
https://uk.rs-online.com/mobile/sear...hTerm=74HCT125
Can somebody advice ones from this list. Thanks.
ok on 8.21 fw work CAN alright great thanks![]()
FxShaw (17th February, 2018)
Hi, I have a question.
I want to find pin and add a key to my VW Up 03/2013. I'm looking for a clone of some sort to keep the cost down, since i'm not running a shop.
Is a carprog clone able to do this through OBD? Or only by dumping the 9S12X?
Or do you have any other suggestions of tools that work for at most 50-100 euro. Tools that I own are a legit VCDS microcan and a clone Zedbull.
Thanks,
Only ODIS online. Clone of the impossible.
I have reset some SRS modules this week.
2 of the modules did NOT clear properly - wrong area of eeprom was cleaned
1 - Nissan Rogue 98820 JM60A - 93c66
2 – Ford Focus 8M5T 14B321 BF – 95160
I have used modified carprog with 150428CAR00577RU firmware.
Can this be corrected?
badziewo (26th February, 2018)
Hello
I need help for my carprog 8.21.it work great for can line but not for k line I try another carprog 9.21 with some a1 but it the some problem reading but with errors.in the a1 the pin 7 is connected to carprog pin 11 .with tester there are continued.thanks
Carprog clone give me (Device locked) as shown in fig .what can I do to open it?
I think firmware 4.01 and serial number 081105CAR001773I
and how I can upgrade software v5.94 to 8 , 9 or 10 (if possible)
Thank you
Is it possible to read Nissan Murano airbag module infineon processor with clone carprog by OBD?
