hi
a question and from me... i want to rework my carprog.... i have to replace that mcp 2512 chip? (i don't know if it is good quality...China cheap hw)
thank's
hi
thank's
Carprog clone work with infineon xc2361? I tried carprog clone 8.21, (mazda airbag), error code read and clear, but no read hlash - connect error...
Panathaole (17th August, 2018)
friends I made a mistake try to erase my carprog with the EPROM mounted now does not read anything I could do
Try and report, post 516
Keep in mind, English is not my native language.
Hi can anyone help i removed AT88 chip to prepare my Carprog for firmware change but when i was cleaning up the solder points from the AT88 chip the solder pot and contact plate from the leg closest to C20 bottom leg rubbed away.Can anyone tell me if i can attach it further over (and where) or is it needing new carprog
sorry for my stupidity but is pin 1
Thanks for any help
hi help me i need active my cprog - 8.21
pc id : 34336-D08EE-D8006-A9837
I got 74hc125D on my CP, can it work or have to be 74hc125M ?
Just a quick update caprog reflashed and soldered at88 eeprom back minus the connection on pin 1 and hey presto everything works and all modules open on 8.21
Hope it helps any one else with the same problem
Cheers
newest carprog v10.93 download here,hope it hels!
https://www.car-auto-repair.com/late...free-download/
Carprog well reworked can read Opel ECUs fine
Actualy is not need to use relay as showed in codecard manuals
tested on edc16c9
seal777 (6th March, 2019)
hello
can the clone with recent version read airbag obd for toyota renesas , or these authorizations are still not available
thank you
