Page 37 of 66 FirstFirst ... 27323334353637383940414247 ... LastLast
Results 541 to 555 of 982
  1. #541
    Trstenik - Thun
    As far a si know MED9.1 isn't on the list of Carprog opel ECUs
  2. #542
    Mar 2016
    Someone got this error while programming
    - Start of preparing flash programming
    - ERROR: Write memory error @ address 0x00200000, word access: Core error.
    - ERROR: Failed to read back RAMCode for verification.
    - ERROR: Failed to prepare for programming.
    Failed to download RAMCode!
  3. #543
    Dec 2016
    UK - South East
    Quote Originally Posted by mikroel View Post
    NO!
    I have changed the processor to a B version.
    It still doesn't detect my device. Any solution?
  4. The Following User Says Thank You to ovidiumarin For This Useful Post:
    mikroel (5th September, 2018)
  5. #544
    Oct 2017
    I have original carprog and today ive tried doing a 2018 land cruiser airbag module 89170-60E60, i read it obd and i get the message OBD2 Adapter not supported , so i remove the module and wire it directly into module socket using A1 multi and other lead , when i try this i have no success reading , has anybody got any help for me on this problem ??
  6. #545
    Trstenik - Thun
    Default Everything Carprog...
    Quote Originally Posted by ovidiumarin View Post
    You made some wrong steps, it must work
  7. The Following User Says Thank You to mikroel For This Useful Post:
    ovidiumarin (12th October, 2018)
  8. #546
    Oct 2017
    any idea what i have done wrong
  9. #547
    Trstenik - Thun
    Quote Originally Posted by Aislingob View Post
    Bad soldering , maybe?
    Check processor if is hot?
  10. #548
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Well you didn't mention whats inside the module... but I am guessing its renesas...if so then you have to use a10 and solder on to board to write.
    🔥Wacka Wacka 🔥
  11. #549
    Oct 2017
    i have managed to modify a10 cable and i have now read the data from the module , when i try to re write the new data i get the message MCU no reply , any ideas on my next step ?
  12. #550
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Send a pic of how you solder the wires onto board.
    🔥Wacka Wacka 🔥
  13. #551
    Jun 2018
    Hello everyone. I have a carprog with the version 10.05 sn 081105CAR001773I here. i have many functions with n / a. Can I unlock this? if so what do I need for that. i am a freshman and ask for help
    Thank you
  14. #552
    May 2016
    Kaunas
    Quote Originally Posted by MrBingo View Post
    Thank you
    use software version 4.01, not 10.05
  15. The Following User Says Thank You to vaicekas For This Useful Post:
    juozas10 (21st September, 2018)
  16. #553
    Oct 2017
    Hello Friends!
    I have CarProg 8.21/10.05. Can I use with 4.01? I did not get it on CD 4.01. Why better than 10.05?
    Thanks!
    BR
  17. #554
    Sep 2016
    Hello all,
    I recently bought a Carprog Version 10.93... Having seen that we have no mention of it here I'm beginning to wonder if I bought a lemon as I am having issues reading a Delphi MT35e ECU. I keep getting errors such as, Could not receive CAN kwp frame, Could not send CAN kwp frame and Could not receive device buffer.
    So far I have replaced a 100n capacitor at location R1 in the A1 adapter with a 103 resistor. I have no wire from pin 16 to the leg of the MOSFET, Is this essential? I have ordered a new MCP2515 and the 22uf capacitors and will replace upon arrival. I have also ordered a JTAG programmer and will flash the carprog if required. Does any one have a stable firmware and software they use?
    Has any one else got a 10.93 and have any known fixes for them?
  18. #555
    Dec 2017
    Mexico
    Hi, Iīm new on carprog. I recently bought a clon carprog and sometimes works but sometimes it doesnīt for airbag. What do you recommend me so I can have the best use of it? Also, if someone can share a manual or let me know how I can connect it to an airbag module by OBDII itīd be very helpful for me.
    I really appreciate all the help you can share with me.
    Thank you.
