Page 4 of 66 FirstFirst 1234567891454 ... LastLast
Results 46 to 60 of 982
  1. #46
    hello buddy, finally my carprog works, can now pull pincode from CAN ecu..
    I have one more issue and that is with EDC16 , Bosch EDC16C9,
    what happens is that, after i read the ecu and display the pincode,
    now when i click on Reset ECU,
    the pincode does not changed to xxxx, it is still the pincode inside, even though i off the ecu for some time and reconnect and read , i still see pincode, please what can i do for EDC16 ecu's in other to get the pincode reset. thank you
  2. #47
    Nov 2015
    Mauritius
    thanks will try to test
  3. #48
    muito obrigado
  4. #49
    Jul 2015
    Quote Originally Posted by eudes View Post
    muito obrigado
  5. #50
    Could someone help me with schematic diagram of wires (pin A1 to DB25) from A1 adapter to carprog, I changed everything in A1 adapter, but it does not work on CAN.
  6. #51
    delete post #51
    Last edited by marco242; 30th December, 2015 at 09:06 PM. Reason: double post, sorry
  7. #52
    FxShaw's Avatar
    Nov 2013
    Outta This World
    When doing Nissan module on bench with infineon...and getting these codes
    B0F8E unknown B058F/B058D Unknown... This is what they really mean..
    Nissan B0F8E Side Collision // B058F/B058D Crash Data
    B1416 Control Unit Bad ---Not good code to have :-). mostly caused by wrong clear.
    B0591 - Rear Collision
    Edit..They Finally listen and add the description in CP..Don't need this anymore. I will update the list if I find more unknown codes and try to make it more accurate.
  8. The Following 2 Users Say Thank You to FxShaw For This Useful Post:
    ecufix (16th April, 2020), PierreTheron (22nd January, 2016)
  9. #53
    Dec 2015
    Provo, Utah
    Hey guys, I have the v07.28 version from china (clone) I'm trying to clear crash on Ford Fiesta with Infineon XC2361. This version said that I need to activate this feature "Ford 2009+ airbag sensors with MAC and Infineon processors programming by OBDII". Is there a way to get this for this clone version. I have the A1 and C1 adapters but the software is not there.
    Any idea. Thanks
  10. #54
    Jul 2015
    Not possible with clone unless it's the russian clone version supposedly..
  11. #55
    Nov 2015
    i have carprog original and tried for clear a srs unit 89170-60350 Toyota LC200 but not working clear dump.
    c66 eeprom
  12. #56
    Nov 2015
    with carprog original you can't read/write data MAC and Inifineon via BDM . only CAN or OBD
    via CAN or OBD reading 99% good but for write have problem for some units
    for reading via CAN ( you need 4 pin sure from unit: Ground , power 12v , CANH , CANL + Resistor )
  13. The Following User Says Thank You to Frankcar For This Useful Post:
    FxShaw (9th February, 2016)
  14. #57
    ...where was Columbus
    Quote Originally Posted by Frankcar View Post
    with carprog original you can't read/write data MAC and Inifineon via BDM . only CAN or OBD via CAN or OBD reading 99% good but for write have problem for some units for reading via CAN ( you need 4 pin sure from unit: Ground , power 12v , CANH , CANL + Resistor )
    Use updated A1 MULTY adaptor. Today I've tried to communicate by regular A1 adaptor with SRS module on board. It have been the 2015 KIA Sorento with 95910-1U180 (Infineon) NO LUCK. But with A1 MULTI I was able to read this module at least. Tomorrow I need to find a solution to clear crash data then I'll try to write back clear dump
  15. The Following 2 Users Say Thank You to Air For This Useful Post:
    Frankcar (13th February, 2016), FxShaw (13th February, 2016)
  16. #58
    Home
    You want to build a10 adapter for Clone why must trim pin 22 or not ?
    Attachment 360011
  17. The Following User Says Thank You to Domi For This Useful Post:
    spacebiker (12th June, 2017)
  18. #59
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Quote Originally Posted by Domi View Post
    Attachment 360011
    Not..Use the exact schematics
  19. The Following User Says Thank You to FxShaw For This Useful Post:
    martinracing (14th November, 2017)
  20. #60
    Nov 2015
    Please help me for adapter A10
    I hava original package full airbag with this adapter
    I think this adapter have problem,if anyone have this adapter please take a photo and send me
    Support carprog told me this adapter clone , now distributor no answer to me
