Page 40 of 66 FirstFirst ... 30353637383940414243444550 ... LastLast
Results 586 to 600 of 982
  1. #586
    Switzerland, Wikon
    Sorry, this AT88 Dump is not correct. To read you need the password for this Chip, otherwise the content will be erased. The correct dump must be much longer. But i respect your goodwill to help
  2. #587
    Nov 2018
    hi is it better than version 8.21?
  3. #588
    Mar 2014
    Poland, Lublin
    Can CP 8.21 clone read/write mac7242 srs unit? Anyone tried?
  4. #589
    Aug 2016
    Stip
    Hello
    I'm interested for the Carpeog Chinese copy, and I need it only for bikes.
    Does anyone has experience with this?
    And please if someone could give me advice which version is most suitable for bikes only?
  5. #590
    Trstenik - Thun
    Quote Originally Posted by Majstorcev View Post
    Hello
    V8.21 last ver. for clones ,the best for car and bikes .
  6. The Following User Says Thank You to mikroel For This Useful Post:
    Majstorcev (12th December, 2018)
  7. #591
    Jul 2018
    Hello
    i used to crash airbag for camry but not success
    i am looking for help to do that
    thank you
  8. #592
    Aug 2016
    Stip
    I find it one v8.21 online on ebay, is it correct model?
    https://www.ebay.co.uk/itm/Carprog-F...frcectupt=true
  9. #593
    Sep 2016
    Quote Originally Posted by addam0w View Post
    I've got problem with my carprog clone 8.21 online. It doesn't read eeprom - shows only 00 values and when I'm reading ECUs by OBD (A1 adapter) it shows wrong values Immo PIN. I changed all 74HCT125 and crystal quartz. Carprog passes all tests.
    Try using Texas Instrument 74HCT125
  10. #594
    Dec 2013
    The problem is the board and components ??? But you can modify
    Enviado desde mi iPhone utilizando Tapatalk
  11. #595
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    hi and from me....
    can you please advice me what else i have to replace-add to improve my carprog?
    i have mark in pictures what i have replace already..... (i can read 24c eeprom without external power now....before replace diodes & capacitors needed ext power..)
  12. The Following User Says Thank You to Panathaole For This Useful Post:
    strumf54 (24th July, 2021)
  13. #596
    Newbie dadoCA's Avatar
    Sep 2018
    Bosnia and Herzegowina
    Need your help guys. Having troubles with China clone after reflash. I sucessfully reflashed the MCU with J-Link, buh when connected to PC it says USB not recognized. Tried different USB cable but same problem. Tried another PC but same same problem. I tried 4.74 firmware and 8.21 firmware.
  14. #597
    Switzerland, Wikon
    have you removed the GND-Pin on the MCU? If this is not the problem, check the USB-Datalines to the MCU. If still not works, then you killed the MCU
    BR Matthias
  15. The Following User Says Thank You to kostelectronics For This Useful Post:
    FxShaw (24th December, 2018)
  16. #598
    Lisbon
    I need some tool to start and Carprog seems a good option, it's not too expensive. But I need to know before buying it if it will be able to read and write full eeprom and flash from a MC908AZ60A 2J74Y.
    Can somebody help me here?
    Thank you
  17. #599
    Sep 2010
    if you must start, buy a original with A1+ and A1 Multi cable
    http://codecard.eu/carprog/carprog-s...prod_474.htmlù
    basic 330 €
    full 1330 €
  18. #600
    Apr 2017
    How do I know if my carprog is original or not?
    Sent from my SM-G950W using Tapatalk
