use the 74HCT125m, my clone didn't work with the 74HCT125D, swapped for 74HCT125m and all good
Hi mates,
I have original carprog long time ago. I bought Volvo dash emulator and new A+ plug but no work for me. I tried like more than 10 clusters and no good luck. Can anybody help me with that?
I read other times this happend to other people.
Thanks in advance
My version of EU clone working well with Volvo dash, of course only models which can be done with A1 or A1 multy.
Newer models where need to be used A1+ i can't do because I don't have A1+.
My version can r&w All epproms and MCUs very well.
74hct125m isn't good solution, with that chip programmer will work better then China clone but still will not work all.
Regarding original programmer, maybe it is older version before they made changes in HW but it have to be checked.
Sent from my HONOR 8X
alclot (14th June, 2019)
Hello does anyone know to get carprog to detect from usb mine arrived today with version 10.93 I believe without checking tried obvious cable 12v + windows XP Windows 7 and Win 8.1. I have opened it to check for visible damaged but everything looks ok I was reading about reflash is there anyway via the micro USB to kick it into life or voltages I can check many thanks Rich the only thing I noticed was bare wire on top of the 12v housing . eBay listing I was hoping to get my Vauxhall security code today aswell ;(
Hi does anyone knows how to use enigma mileage correction connections to change the milage using carprog. As I have seen Codecard.lt has uploaded the wiring conversion for A10, A4 etc to enigma c7, c11 etc. The main problem I'm facing is I have connection of odometer board, i.e hyundai i10 (viston no eeprom) but i don't know in which function I should read mileage hope you understand. Screenshot_2019-06-27-12-54-03-724_com.android.chrome.jpgHYUNDAI I10.pdf
Sent from my Redmi Note 7 using Tapatalk
U can use new carprog adapter
https://youtu.be/YHzIQGU2_dw
strumf54 (24th July, 2021)
Just ordered this carprog from ebay. after ording i read up about it needing to be 8.21 to use the online functions. im new to all this carprog bits and like to learn is there anyway to downgade from 10.93 to 8.21?
https://www.ebay.co.uk/itm/UK-Latest-Version-Carprog-V10-93-Carprog-Full-with-All-21-Adapters-Airbag-Reset/323829762624?ssPageName=STRK%3AMEBIDX%3AIT&_trksid =p2057872.m2749.l2649
I already see a new topic on the forum "i need help to rework my carprog"
i have searched for downgrade from 10.93 but cant seem to find any info regarding it unless im searching the wrong thing.
im only looking for mileage correction on a p6 passat i have just brought a colour cluster to change from my black and white one would 10.93 work?
I've been considering buying one of these recently, I wouldn't know where to start though (clone though, I've spent way too much on diagnostic/tuning over the last year) What's the best to buy? EU 8.21? a certain colour pcb?
With new model of adapter and eu clone everything working well
If you need really good working CLONE..
I don't understand what you're trying to show me - that I need 9.31 and new adapter?
Last version for clone is 8.21(9.31 is very simmilar and can be used too but not all options)
All other, higher version, are useless if u don't have related firmware because non of new options will not (can't) work.
Especially versions higher then 10.05, because many options become online.
Second thing is :
Non of clones from Ali or eBay can not work properly so don't expect miracle for 40-50 eur.
Only EU clone can work well as original and only v8. 21.
So I fu want to buy Clone u can forget Ver. Higher then 8.21.
Hope this will be clear enough.
NEW model adapter v2018 is just upgrade of old adapters and it exchange 5-6 different old adapters for lower price.
Thankyou, can you (or anyone) suggest where to get a good one, preferably with the new adapter?
