Page 52 of 65 FirstFirst ... 242474849505152535455565762 ... LastLast
Results 766 to 780 of 970
  1. #766
    V12.86 is the current version?? Or no?? I meant with v8.21 clone till what year. But I am consdering getting carprog original with subscription. I think its the best option for me if I dont want to buy software license for everything right now.
    Quote Originally Posted by catalinosonesti View Post
    Hy, can you do till 2018 with v12. 86. I send you a list
  2. #767
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    yes ,if you want take original ,now they have big promotion from EASTER.
    look www.codecard.lt
    wbr
  3. The Following 2 Users Say Thank You to catalinosonesti For This Useful Post:
    Col19 (12th October, 2020), senator6569 (21st June, 2022)
  4. #768
    Yeah I think I will order original today. Dont want to bother with clone and all the necessary changes to make it work. Is v12.86 the latest or no??
  5. #769
    Mar 2019
    east nord pole
    Yes, till now 12,86 but every 4-5 days make update On internet, work wery Good, suport tehnical is On same Day, if you have some problem they see and send you all suport.
    Wbr
  6. #770
    I already ordered my carprog original waiting on shipment. But I also came across this for anyone interested.
    https://www.ebay.com/itm/CARPROG-8-2...QAAOSwT6pVyacP
  7. #771
    Feb 2020
    hello i have carprog 8.21 someone able to calculate keygen for me serial is D4B06-D0829-E9006-A3B5C thanx in advance
  8. #772
    Aug 2008
    joey90
    FRQUAGXC97XKQXHF3AVTQA737JLZRG74L5LBVKW673CYC72ZKK SZ4MGLKX328RXSQ9
  9. #773
    how to connect carprog programmer for read airbag citroen c5 /9641968380
    Motorola 912b32
  10. #774
    Mar 2019
    east nord pole
    Quote Originally Posted by belcitroen View Post
    Motorola 912b32
    Use A10 adapter 3 wire only 3,3 - 5V blue is reset
    Good lock
  11. The Following 2 Users Say Thank You to catalinosonesti For This Useful Post:
    flikis (31st October, 2021), senator6569 (21st June, 2022)
  12. #775
    May 2014
    UK
    Default Carprog ? Aprilia Pegaso 650 Strada 24C16
    Hi, can someone help please I have a dash from a 2007 Aprilia 650 Pegaso Strada with the 24C16 chip and it is checksum protected, the only software I can find that has this listed is carprog, but heard it's unreliable so not 100% sure about buying as yet, pleasee could someone try the dump attached and post to me changed to 28500km, the miles is duplicated in lines 2 and 3, and forms 8E 75, and the checksum is 80, it should give 30094kms (18,808 miles), I need 28500kms or there abouts. ? Cheers
  13. #776
    autocargo's Avatar
    On chinese clone firmware 8.21from this forum can read MCU XC2361A by obd? Anybodytried?
  14. #777
    Jul 2016
    USA
    Hi, Im trying to clear GM 21992627 by using "GM DIAG 0.4" by using connection by pins, I "read fault memory" then "clear crash data" but these codes come up again:
    B0013 - Right Front/Passenger Frontal Deployment Loop Circuit
    B0014 - Right Front/Passenger Frontal Deployment Loop Circuit
    B0043 - Left Front/Driver Frontal Deployment Loop Circuit
    B0044 - Left Front/Driver Frontal Deployment Loop Circuit
    I noticed everytimereading these gm units by OBD carprog always reads different data slightly
  15. #778
    May 2020
    glasgow
    Default some expert direction required
    Hi friends and all community members., I used the carprog version 10.93 to determine the security code from a corsa d. It did provide this ok. I then used the airbag section to try and clear crash data. It does claim to have cleared it, but I when use opcom it still see the fault codes and will not clear. During the crash erase process it did come up with ID not found( see picture)it continued through the process, with a message crash data cleared. I am missing a stage in this process.
  16. #779
    Jul 2016
    USA
    did anyone use CarProg Gm - Diag - GM v0.4 successfully ? I tried on many SRS units it never clears crash data and doestn clear faults, same data is showing in dump before and after crash clearing
  17. #780
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Quote Originally Posted by borshch View Post
    I used it just last week.. don't recall ever had any issue before with it at all.
    🔥Wacka Wacka 🔥
  18. The Following User Says Thank You to FxShaw For This Useful Post:
    borshch (20th May, 2020)
