Page 55 of 65 FirstFirst ... 5455051525354555657585960 ... LastLast
Results 811 to 825 of 970
  1. #811
    Thumbs down
    Quote Originally Posted by alba2 View Post
    Hy to all .I find this tutorial about flashing carprog without lift the pin 55,remove the At88sc .Someone try this ?
    Posted on March 30, 2018 by eobdtool.co.uk
    I did all the tutorials regarding the flashing of the carprog. I tried the method that I posted to you. It is functional, I just simplified and modify the flashing procedure for that it is simple for the novices (I am one myself).
    I just observed and tested the different methods in order to arrive at something simple steps.
    1) No need to unsolder AT88SC.
    2) no need to lift pin 55 or solder a wire on the pin 55 (according pcp) .
    3) the reset is done on a single pin as in the photo.
    4) photos of the connector that I made.
    I did not put you the flashing procedure (there is a lot of post on this subject). I use the segger software “flash V 4.98” and of course the segger interface jlink .
    PS look at the photos and make sure you have the same pcb. have a good flashing.
    carprog easy way to flash
    it is not correct to take ownership of the work of others, in this case my work, shame on you !!!!!
    POSTED ON MHHAUTO (habbou)AND OTHER WEBSITE !!!
  2. #812
    Apr 2017
    Quote Originally Posted by habbou View Post
    He should apologize but I'm sure he meant no harm. Thank you also for posting this in MHH Auto. Not getting enough help here though.
  3. #813
    Aug 2019
    hi everyone. just dont waste your money. i have the full original software and half of the stuff doesnt work. today i messed up a cluster on a 2013 ford explorer because of carprog. i have read the miles on the car which was correct and when i write the correct mileage with carprog cluster said ERROR. not the first time. if you are doing infinions, carprog is very good and thats it! im just not happy spending so much money on original and mess up the cars. now i have to buy a new cluster!!! bad tool!!!
  4. #814
    Aug 2019
    another one which is bmw ews3 key programming? does not work people!
  5. #815
    Feb 2019
    Hi guys.
    I've bought for china clone of Carprog v10.93 but I have an problem, that Carprog program itself is not a FULL version.
    I wanted to read/flash A3 2010 Dashboard via OBDII but the feature shows as "not active".
    Is it possible to unlock it by firmware reflash?
    Thanks!
  6. #816
    Aug 2008
    Quote Originally Posted by meciu View Post
    Hi guys.
    Thanks!
    this is the problem people have thinking they are buying the latest version of carprog
    the v10.93 is just software and people should realise this before buying
    firmware on the carprog you have is firmware version 4 you need firmware v8 which is the last free firmware
  7. The Following 2 Users Say Thank You to tango For This Useful Post:
    catalinosonesti (5th September, 2020), PierreTheron (30th September, 2020)
  8. #817
    Nov 2018
    3 floor on Red Dwarf
    Quote Originally Posted by efodela View Post
    I see various wiring to the 12v power input across some transistors and some have a resistor. Can someone tell me why its being done and are they done on specific boards?
    Attachment 723654
    Hi, it looks like worth a try extending or better strongest ground line not for transistors, but for voltage regulator. I mean if better solution is add some condensator on every downgrade voltage line.
  9. #818
    Nov 2018
    Welp i broke pin 55 on MCU.. what can i do to fix it? can i buy another similar mcu and install it?
    Chmm, maybe if you have micro or modelmaking grinder and of course eagles (eye)sight then you may try it repair. Only littlebit pieces suffice to soldering small piece wire and thats it, mcu is back!
  10. The Following User Says Thank You to automechanik For This Useful Post:
    salimane (5th December, 2020)
  11. #819
    Apr 2017
    I bought new MCU b version from Aliexpress. I can replace it and reprogram?
    Sent from my SM-G975W using Tapatalk
  12. #820
    Nov 2018
    I think if same mcu with suffix B is right for repairing, but everybody some know about quality from china, sometimes it work, sometimes not. When u have hotair station its not problem desoldering old mcu and trying your new piece installing back and worth a try programming it. But be careful, i recommend before reprogramming mcu too desoldering from pcb eeprom at88. But i still mean if better solution before changing it is worth a try repair mcu like i write in post above.
    Cheers
  13. The Following User Says Thank You to automechanik For This Useful Post:
    efodela (11th October, 2020)
  14. #821
    Apr 2017
    Thank you @automechanik will try to fix mcu first.
  15. #822
    Jan 2019
    Hi every one. Can I adjust mileage on Chevrolet spark 10 plate with chinese carprog v8.21?
  16. #823
    electromech's Avatar
    Behind a large rock
    Quote Originally Posted by huseyin0240 View Post
    I second this alot of features advertised does not work ...And I have Full original unit
  17. #824
    FxShaw's Avatar
    Nov 2013
    Outta This World
    There is always more than one type of clusters..I used cp on other ford and it works fine as long its the same version they advertise...This f150 2013 is simple...just take out and read 24c16 back...this vehicle is super easy to do..as for ews3 I did a few and no issue ����~♂️.. CP is not the best at dash at all means but no tool is perfect to begin with..I had expensive tool that fail at some dash and cp got it right. 90% of the time I use other tool for dash.. If you bought only for dash then that was a mistake.. I more disappointed with other tools to be honest...cp is cheap compare to the rest of other tools I have that failed sometimes.
    🔥Wacka Wacka 🔥
  18. #825
    Mar 2018
    Hungary
    Hii
    I have carprog,8.21 version XXXXXXXXXUA.I made all modify.But not read 24c02 eeprom.Just 24c02,all eeprom ok.some idea for someone?
