Page 56 of 66 FirstFirst ... 6465152535455565758596061 ... LastLast
Results 826 to 840 of 982
  1. #826
    Nov 2018
    3 floor on Red Dwarf
    Through OBD or direct from pcb or direct from alone eeprom? Which is producer your eeprom?
  2. #827
    Mar 2018
    Hungary
    Quote Originally Posted by automechanik View Post
    Direct from alone eeprom. 24c02 dump immo off and pin code ... procedure
  3. #828
    Nov 2018
    So its variable depend on producer eeprom chips, but if any other chips is readable without problems i mean if good step on right way is checking what is value VDD for your chip from CP.
  4. #829
    Anyone where I can buy a good working clone v8.21?? That needs the normal rework and so on??
  5. #830
    Apr 2017
    Thats hard to find. I always get the newer ones which seem different on the board with pin 55.
    Sent from my SM-G975W using Tapatalk
  6. #831
    Home
    Can someone measure voltage on TX and RX in IDLE ? On adapter for RNS510.
  7. #832
    SadCriss's Avatar
    At the Garage
    Hello to you all!
    I have a problem whit my carprog and would like to ask if there is any way that I can fix it...
    I have original Carprog and when I conect it to the pc and open software the software does not recognise the serial number of the device.
    If I insist pluging it in and out sometimes I have a partial serial number apear...
    Anyone have these problem before? I have try to search the thread but didnt find something that leads me to fixing it.
    Thank you
    If It helps you try push the: Thanks and REP
    I do the same each time it helps.
  8. #833
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    Quote Originally Posted by SadCriss View Post
    Hello to you all!
    Thank you
    If you have shortcut that s happen or do have subscription?
    When open program do it direct from carprog folder ,aplication ,then conect wery fast .
    They have a lot to security Update, now have V 13.09
    Best regrads .
  9. The Following User Says Thank You to catalinosonesti For This Useful Post:
    SadCriss (23rd October, 2020)
  10. #834
    SadCriss's Avatar
    At the Garage
    Quote Originally Posted by catalinosonesti View Post
    Best regrads .
    Yes I have full airbag. I always open the software from desktop shortcut. I wil try what you have sugested and report back
    Thank you
  11. #835
    Jan 2020
    Can anyone please share flash dump? 150428CAR00542UA.bin (not lib)
  12. #836
    Jul 2019
    far far away
    here u go matey
  13. The Following 4 Users Say Thank You to alpntrb For This Useful Post:
    adamwajda (21st July, 2021), alladdin205 (5th September, 2021), johnmarsh (24th October, 2020), Papiti56 (4th March, 2021)
  14. #837
    SadCriss's Avatar
    At the Garage
    Program now see interface all ok but crashes a lot and cant write eeproms.....
  15. #838
    Nov 2018
    Try check all lines power source first - output from voltage stabilizers and secondly try change all stabilizing condenser around voltage stabilizers
  16. #839
    Oct 2020
    hi I need to know if are there information about reset crash of ecu Autoliv 620595100 for citroen c elysee or peugeot 301
  17. #840
    Feb 2020
    hi i need please pack for bikes is any solution accept 240 euros???
    i have a reworeked carprog
    and 1245 edition
  18. The Following User Says Thank You to silver1983 For This Useful Post:
    senator6569 (21st June, 2022)
