Page 58 of 65 FirstFirst ... 8485354555657585960616263 ... LastLast
Results 856 to 870 of 970
  1. #856
    May 2019
    Quote Originally Posted by tango View Post
    some have problems reading eeproms
    That’s why people rework clone. So they are able by to read / write eeprom
  2. #857
    toyota123's Avatar
    Sep 2019
    Quote Originally Posted by paixfrawg View Post
    When you try reading does it say “no id found”
    I try doing two Nissan modules recently and it didn’t want to read .
    no it does not show "no id found" , it's all work fine , when i read all of the dump change to FF , it also doing verify and says VERIFY OK , but the dump is FF
  3. #858
    May 2019
    Quote Originally Posted by toyota123 View Post
    Hm. Okay. I tried reading manually and I got all 00..
  4. The Following User Says Thank You to paixfrawg For This Useful Post:
    toyota123 (4th January, 2021)
  5. #859
    toyota123's Avatar
    Sep 2019
    yes same problem i think . you have any solution ??
  6. #860
    May 2019
    Nope. I email who I bought it from but he isn’t replying .
  7. #861
    toyota123's Avatar
    Sep 2019
    i will find the solution , and be sure i will share it i think the flash file that i write to chip with jlink is bad , myb !
  8. #862
    May 2019
    Thank you 🙏 let me know if you figure it out
  9. #863
    Aug 2008
    easy way for a test is to reflash with fw4.01 then see if it reads eeproms ok
    then reflash with fw4.74 and do same test
    then reflash with fw8 and do same tests again
    if it dont read on any then pcb needs reworking
    if it reads on fw4.. then its a fw issue
  10. The Following User Says Thank You to tango For This Useful Post:
    toyota123 (6th January, 2021)
  11. #864
    May 2019
    I don’t know how to do that hahah . I’ve been doing airbag modules for one year. If I had money for an original one I’d rather get one rather than clone.
  12. The Following User Says Thank You to paixfrawg For This Useful Post:
  13. #865
    Aug 2008
    theres instructions all over the net for you to follow on reworking carprog and for reflashing carprog
  14. #866
    May 2019
    Yeah I’ve watched a few videos on YouTube. I think I’ll just save up for the original one
  15. #867
    What is currently the best place to buy carprog full v8.21???
  16. #868
    May 2019
    Quote Originally Posted by AudiS4 View Post
    I don’t recommend a clone unless it’s reworked.. and even then don’t expect it to be super great programmer. It’s ok. Mainly for airbags.
  17. #869
    Gonna rework the clone but need a good place to purchase from. Only planning on using it for airbags and maybe 912 motorola mcu thats about it. Any place that has decent quality clone that ships to usa without having to wait a month??
  18. #870
    May 2019
    I purchased off someone from car technology.. already reworked with an adapter it was like $200.... I remember it took a while to get but I think it was cause this COVID thing.... recently for some reason it isn’t reading correctly though. When I try reading a module by part number it keeps saying “no id found “ and when I try reading thru eeprom type it’s bad readings. Idk if it’s the Carprog or adapter but I got over it.. I have ultraprog , cpt (not all activations ) and looking to get original upa or etsmart ... and have airbag service tool
