Can we reset Chinese carprog 4.74 tokens with software? I saw a couple of software online...don't know if I should use them or not.
Yes its called the countdown and yes..Same way you upgrade 4.01 to 4.47, its the same exact procedure to reset the counter.
No its not possible with version 4.74.
Meat-Head (3rd September, 2015)
I have original carprog with 2015 update. i bought the update specifically to repair volvo XC60 module. it uses 9S12XDT384 but carprog does not read at all. does anyone else have this issue?
You talking about the dash right.. you have to use the A1+ adapter and A21 VOLVO CAN, its not the same as A1 cable.
no was for xc60 airbag, but they confirmed today with me that is was mistakenly put on there so they will take it off soon. luckily support was very helpful and did not have issues with refunding me the money for the upgrade since it is false advertised.
FxShaw (17th August, 2015)
Ohh ok..Good to know.
mates after doing reset counter now when i want use y carprog get message asking for update the lib file please may some one to solve this
Everything will be back in order - All my respects to DK's members.
After you update did you use the new lib file instead of the old one?
malabar969 (16th September, 2019)
Which reset are you talking about anyways? did you upgrade yr carprog from 4.01 to 4.74?
Oh the usb reset...Been a while since i used that...If I recall correctly you replace lib file with one in d/l folder unlockok.exe and go to internet update and that shold be it.
