Page 65 of 66 FirstFirst ... 155560616263646566 LastLast
Results 961 to 975 of 982
  1. #961
    Becoacamba's Avatar
    AnyWhere
    Default Try This, report
    Try This, report
  2. The Following User Says Thank You to Becoacamba For This Useful Post:
    lvkas (20th June, 2024)
  3. #962
    Jul 2011
    Hello, I need to reset the airbag on a 2010 Skoda Fabia, and I want to buy to do it myself. But I'm in a mess.What do you recommend? Carprog 8.21, 10.93, 13.77... o Carprog 2, or better upa usb programmer...Thank you so much
  4. #963
    Smart66's Avatar
    Dec 2020
    Online functions don't work in Carprog 13.77 When I try to use them I receive error " CAN`T CONNECT TO REMOTE SERVER". Annyone with same issue? It should work in every 13.77 version?
  5. #964
    Jul 2021
    Online in 13.77 does not work, 8.21 used a "fake" server, while 13.77 does not use it
  6. The Following User Says Thank You to StabiloBoss For This Useful Post:
    carradio2001 (9th May, 2024)
  7. #965
    Smart66's Avatar
    Dec 2020
    Have you got 13.77 version? As far as I know online functions should work in 8.21 version
  8. #966
    Jul 2021
    Yes, I have versions 13.77 and 8.21 but, like yours, 13.77 does not connect to the server, 8.21 works on a "fake" server and online works.
  9. #967
    Smart66's Avatar
    Dec 2020
    13.77 version is really useless. I think that its firmware can be downgraded to 8.21 version. Will you try to do it?
  10. #968
    Jul 2021
    I use 8.21 with firmware from 13.77, I just copied the .lib file from 13.77 to the 8.21 folder and it works normally for me, I didn't downgrade the firmware
  11. #969
    Smart66's Avatar
    Dec 2020
    I've already tried that, all offline functions worked normaly as in 13.77 version but when I used online functions it couldn't establish communication with car although online function worked. That issuse should be related to device firmware which must be downgraded and use .lib file from real 8.21 version
  12. #970
    May 2021
    need that pass pls
  13. #971
    Aug 2008
    Quote Originally Posted by shamsaka View Post
    Any one face same issue for tc22xx airbag via carprog, blank page always
    same problem
    did you find a solution?
  14. #972
    Jun 2024
    Thank You to FxShaw For This Useful Post
  15. #973
    Jul 2024
    Hi guys I’m new on all of this first of all thanks for who can respond me,
    I’m trying to have access to my BMW 328i 2007 I need to clear some codes after I had a battery issue
    And some codes of lights
    Can somebody help me and guide me to the correct way to to all of that?
  16. #974
    Jan 2019
    Can I ha e the password please
  17. #975
    Mar 2019
    Scandinavia
    Exclamation
    Quote Originally Posted by ArmandoRodri View Post
    I belive you need to re-flash FRM and you also need to convert the file.... I always use VVDI and FRM no-soldering adapter for this... It's 2 min jobb
    learning by doing, learning by experience... please thx is I helped you
