Page 7 of 65 FirstFirst ... 234567891011121757 ... LastLast
Results 91 to 105 of 970
  1. #91
    Spain
    Quote Originally Posted by teamtuner View Post
    like this...
    the instructions do not tell me anything about how I have to program the eprom AT88SC
  2. #92
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Quote Originally Posted by pacomasi View Post
    That's cause you just have to remove the at88sc and not do anything else to it, until you finish programming mpu and then put it back on board.
  3. The Following User Says Thank You to FxShaw For This Useful Post:
    pitake (14th April, 2018)
  4. #93
    Spain
    Quote Originally Posted by FxShaw View Post
    It is that my mistake has erased the eprom me AT88SC .and I want to program it again
  5. #94
    Jul 2015
    You can't. Its encrypted!
  6. The Following User Says Thank You to gentiabazi For This Useful Post:
    FxShaw (22nd March, 2016)
  7. #95
    Feb 2016
    Hi. Can I read AT91SAM7s256 with xprog? I think no way but just answer for case.
  8. #96
    autocargo's Avatar
    Quote Originally Posted by gsmnavi View Post
    No way... Use Jtag, Segger, even you can build simple thing with resistors... Only have to search on forum.
  9. The Following User Says Thank You to autocargo For This Useful Post:
    gsmnavi (22nd March, 2016)
  10. #97
    Sep 2015
    thank you for this thread
    and i have Question
    i cant read any
    Motorola mcu with my careprog ?
  11. #98
    Aug 2008
    how does the at88c get erased?
    i have reprogrammed my carprog and at88c isnt effected
  12. #99
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Quote Originally Posted by tango View Post
    Only thing you suppose to do with at88c is to desolder and solder it back when reprogramming it back.don't try to read or write to it and it will be fine :-)
  13. #100
    Aug 2008
    i know this, but i never remove it and neither do many others, i think the removal was originally mentioned just in case anything happened to it.
    its been noted a few times that it dont need removing this is why im asking how does it get erased if only reprogramming the mcu, jtaging the mcu doesnt effect the at88c so how is it being erased ??
  14. #101
    Dec 2015
    Also, I noticed that adapter A15 pinouot differs from the pinout diagram on the codecard website. Does anyone know what cable/color is for K -line on clone A15?
  15. #102
    Dec 2015
    I have carprog clone 7.28. I have managed to read eeproms. But I have never been able to clear crash data directly, Is there something I need to do to this version? or only earlier versions need chip change/flash? thank you
  16. #103
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Quote Originally Posted by joeguzman89109 View Post
    Yea you have to use carprog version 4.01 software
  17. #104
    otojm's Avatar
    Feb 2012
    Kepler 22b
    Quote Originally Posted by carprog45 View Post
    my firmware carprog V8 AT91SAM7S256snRA here now + lib v8 + serial + bonus YES V8...... FREE
    https://yadi.sk/d/M_PpAJzRq3CX5
    thank please
    hi please who can confirm that i can flash my carprog v4.74 withis v8 and have more activations? Regards
  18. The Following User Says Thank You to otojm For This Useful Post:
    Brown012 (22nd January, 2023)
  19. #105
    Feb 2016
    Hi! Today I try to update cargprog with segger j-link on win7 32bit. When I start to programm this message comes on: Program (0x0 - 0x5B5) does not fit into selected flash sectors. I select ok and see what doing:
    Initializing CPU core (Init sequence) ...
    - Initialized successfully
    - JTAG speed: 12000 kHz (Fixed)
    - CPU clock frequency: 31248 kHz (Auto detected)
    - J-Link found 1 JTAG device. Core ID: 0x3F0F0F0F (ARM7)
    - Connected successfully
    Programming target (1462 bytes, 1 range) ...
    - Program (0x0 - 0x5B5) does not fit into selected flash sectors.
    - Program relocated for programming by 0x100000 bytes
    - RAM tested O.K.
    - Target programmed successfully - Completed after 8.010 sec
