is there any higher version than 4.74? or 4.74 with removed counter?
Hello Everyone, i am new here.
anyone tryed to reverse engineer 4.74 ARM binary with IDA pro + qemu? to see which parts of code can be modified in order to remove counter and enable new functions?
i have some success in understading what is hidden inside this binary but not skilled enough for now to mess with counter
also what are these red values (vFFFFFF60 etc..)? address into RAM or something else?
problem is that im not really familiar with ARM so no idea how to enable JTAG (there is security bit setted by this firmware which disables JTAG)
if i manage to enable JTAG then i can download firmware after counter decreases and see exactly which part of memory is modified
then patching it to not decrease will be very easy to make
ben shence FxShaw
Ciao a tutti, sono nuovo e sto seguendo tutte le discussioni carprog e xprog, ho entrambi e li ho cambiati entrambi con JTAG, il mio problema ? che ho bisogno dell'abilitazione s7.20, vale a dire la riparazione del cruscotto da OBDII per AUDI A3, TT, R8 nuovo 2010+, qualcuno ha sbloccato questa funzione? nel suo firmware Ho provato molti ma per ora nessuno ha questa caratteristica. Grazie mille ? uno dei migliori in circolazione comunity.
Could you repost in English please mate ?
Thank you...
DashProg (4th June, 2016), David Crockett (18th February, 2021), FxShaw (9th June, 2016)
Sorry for bumping this thread but I haven't got a definitive answer for my question anywhere.
Can I erase the airbag code F3-11 on a 2007 Honda civic using carprog? Its a hard code that can't be resetted by the OBD 2 reader, I am using a solus ultra and it doesn't work. So can anyone tell me if I can use carprog to remove the code and reset the srs module memory? Thanks
fredric36 (24th June, 2016)
Thanks so much for replying, I appreciate it, I have another question
Can I buy this carprog and modify it to work with my application? I asked the ebay sellers and they said it wont work :/ so I am not sure, please advise.
http://www.ebay.com/itm/291516443362
