Page 8 of 65 FirstFirst ... 3456789101112131858 ... LastLast
Results 106 to 120 of 970
  1. #106
    autocargo's Avatar
    Quote Originally Posted by gsmnavi View Post
    Hi! Today I try to update cargprog with segger j-link on win7 32bit. When I start to programm this message comes on: Program (0x0 - 0x5B5) does not fit into selected flash sectors. I select ok and see what doing:
    Initializing CPU core (Init sequence) ...
    - Initialized successfully
    - JTAG speed: 12000 kHz (Fixed)
    - CPU clock frequency: 31248 kHz (Auto detected)
    - J-Link found 1 JTAG device. Core ID: 0x3F0F0F0F (ARM7)
    - Connected successfully
    Programming target (1462 bytes, 1 range) ...
    - Program (0x0 - 0x5B5) does not fit into selected flash sectors.
    - Program relocated for programming by 0x100000 bytes
    - RAM tested O.K.
    - Target programmed successfully - Completed after 8.010 sec
    I think is done now. You should try it on with carprog software. Don't forget to place the right lib file on carprog folder.
  2. #107
    Aug 2008
    sorry double posted by mistake
  3. #108
    Aug 2008
    Quote Originally Posted by otojm View Post
    hi please who can confirm that i can flash my carprog v4.74 withis v8 and have more activations? Regards
    stay with 4.74 because this is not v8
    its edited v4.74
  4. The Following 2 Users Say Thank You to tango For This Useful Post:
    otojm (26th April, 2016), PierreTheron (26th April, 2016)
  5. #109
    Feb 2016
    I try it with software but without succes. "No device attached".. What I need to do now ?!
  6. #110
    otojm's Avatar
    Feb 2012
    Kepler 22b
    Reflash you mcu with working firmware 4.1 or 4.74 and see !
  7. #111
    Feb 2016
    You mean the firmware in the pdf in first post is wrong? Can you give me working .bin file
  8. #112
    otojm's Avatar
    Feb 2012
    Kepler 22b
    Quote Originally Posted by tango View Post
    its edited v4.74
    yes you are right they change SN in adress 00009B40
    But also those minor bytes (see pic)? why they do it for what benefit ? the old 4.74 work well ?
  9. #113
    Feb 2016
    can you uploade working AT91SAM7s256.bin file?
  10. #114
    Aug 2008
    i think just to fool people
  11. #115
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Correct! Cause I tried it and gain nothing when I tried v8..stick to 4.01 and 4.47
  12. #116
    Feb 2016
    everything is ok. My friend send me working .bin file..
  13. #117
    PierreTheron's Avatar
    Centurion,South Africa
    Get all from here m8 ..
    I have been using it till now ...
    http://www.digital-kaos.co.uk/forums...ything-Carprog
  14. The Following 3 Users Say Thank You to PierreTheron For This Useful Post:
    ecufix (16th April, 2020), FxShaw (26th April, 2016), svallecilla (8th April, 2020)
  15. #118
    Dec 2015
    Thank you FxShaw for adding carprog software v4.01 agian. Highly appreciated!
  16. #119
    otojm's Avatar
    Feb 2012
    Kepler 22b
    i use this one v4.74 without problem ,try it & see if you still have "no device attached" then probably your mcu is damage.
    but you must be sure you have program and verify successfully your mcu...
  17. The Following 8 Users Say Thank You to otojm For This Useful Post:
    deteli (30th March, 2018), ecufix (16th April, 2020), Jazzy103969 (5th August, 2018), Katana1156 (23rd May, 2016), motocarlos (28th October, 2018), n599fbm (18th May, 2018), nihadbeg (27th April, 2019), samyy (29th September, 2016)
  18. #120
    May 2016
    thks for you pose
