Page 62 of 65 FirstFirst ... 1252575859606162636465 LastLast
Results 916 to 930 of 971
  1. #916
    May 2022
    Si, funciona bien!
  2. #917
    al70's Avatar
    Nov 2017
    Éire
    hi all, i need to reflash a carprog unit, so i bought one of these little daplink units but the connections look different to the segger unit, maybe they're marked different, heres a link to the product, anybody use this daplink ? will it work to reflash the carprog, cheers
  3. #918
    Jun 2022
    your a star
  4. #919
    al70's Avatar
    Nov 2017
    Éire
    will it work for carprog ?
  5. #920
    Aug 2019
    Hi i am trying to read immo data from a 2012 vw t5 cluster with a CarProg clone. it will read the part number and type but then i get security access error try 2012up or color selection, when i try that i will get the same error. I have modified the eeprom with the FFs and i get the same fault. i also tried Grounding the SDA pin but i get the same error. if i have everything stock i will get Immo Active. What could be wrong? i have 8.21 online version of a rebuild clone.
    I have change the capacitors and the 4 74HC125 ics. I have also replaced the capacitors and the MCP2515 in the A1 Adapter also flashed the firmware to 8.21 with serial 150428CAR00491KW
    it will read the part number and the type of the cluster so i think something is working?
    what more do i need to do?
  6. #921
    Jul 2022
    Miami
    hi, thanks for the programs, let me try and see if I can make it work,
  7. #922
    Mar 2019
    Hi guys.I have original Carprog that’s been sitting for a while.Now when I try to update it,it doesn’t even connect to server.Did they stop that and now you have to pay subscription to use Carprog or is my ISP blocking my access?Thanks
  8. #923
    Junior Member wesleyheida's Avatar
    Sep 2020
    The Netherlands
    Hello,
    I am trying to read my micronas cdc32 flash + 24c32 by obd Carprog A1 cable to get pin, cs, mac, keys etc
    I have read 24C32 manually by A6 cable clip and saved for backup. (verify ok)
    Then I FF 0x812 - 0x9BF to delete immo data and get in service mode.
    Then written the service mode bin back to the 24C32 chip. (verify ok)
    Then Read the 24C32 chip by a6 clip to confirm immo data is FF out (all ok)
    Put cluster back together. Connected via obd A1 cable bench setup.
    Launched carprog golf5 2007 -> 0.5
    Carprog see partnumber, coding, type and SW so can communication works. It also reads fault codes.
    Opened original eeprom dump 24C32 to write via OBD
    When trying to write it stays at ''entering write mode... attempt 1'' then it asks to turn ignition off for 5 sec etc.. so it fails to write...
    Anyone knows why it fails to write original dump back to 24C32 via OBD A1 cable?
    It is a carprog clone. came with 4x hct125m chips (manually read/write 24c32 works, so looks like good clone)
    A1 cable looks good as original. all resistors and capacitors in the right place.
    Everything is performed with 12V to carprog.
    I have attached pictures from carprog front/back and A1 cable + 24c32 dump original and service mode
    Method I am trying:https://codecard.eu/index.php?act=vi...Id=433&ccUser=
    FIXED! Use carprog 5.31 instead of 8.21
  9. The Following User Says Thank You to wesleyheida For This Useful Post:
    serikpay (27th March, 2023)
  10. #924
    Dec 2017
    Micronas and car prog I Never read success
  11. #925
    Sep 2020
    The Netherlands
    Quote Originally Posted by wesleyheida View Post
    Hello,
    Fixed! Software issue. Installed carprog 5.31 and works like a charm!
  12. #926
    Aug 2019
    Should the Carprog clone work with clusters from a 2012 vw transporter? having trouble reading it for cs pin and so on. it only read the model number but nothing else. the carprog is reworked with genuine ics.
  13. #927
    metallo's Avatar
    Jun 2018
    Italy
    hi! will they ever implement spc560 airbag in carprog? or only online paid?
  14. #928
    Jan 2023
    Can someone help me with 111728car98791kw.lib file?
  15. #929
    Feb 2018
    Ravensburg/Germany
    i am trying to fix fault code 65535 (ecu defective) on an 2001 Audi TT with CarProg 10.93 (clone device), but it doesn't clear. I can read fault code, but it shows only for 1 second.
    I can read Eeprom, so connection to ECU can't be problem. Clear crash data takes some seconds, but fault code is not away then.
    I tried to find someone here on digital-kaos to edit my eeprom file, but no one responds. Maybe someone can help me with this fault code, i would pay for help!
    Thank you
  16. #930
    Mar 2023
    Hello! I am facing exactly the same issue. Is there a link that I could download the carprog 5.31 version?
