FxShaw (28th February, 2019)
FxShaw (28th February, 2019), mkorganashvili (28th February, 2019)
HI, are u familliar with carprog? do you know how to adjust mileage on 2013 / 2015 chevrolet utility bakkie (GM)
Hello !
I changed the software and firmware to the 3rd post. I have repaired the carprog and the A1 cable as described.
When IMMO reading on the 2005 Caddy, Touran 2003 with A1 cable works perfectly! Trying to read IMMO on golf 5 2005, golf 5+ 2008 and Passat b6 2007 I have a problem. Reads only the dashboard model, coding and nothing more. Says it reads, reboots the dashboard and nothing more. Can't read mileage too. On the same cars, can read Eeprom through A1 without any problem (no matter what model eeprom I choose ).I'm sure carprog and A1 works properly because it reads Caddy and Touran without any problem. I watch videos of colleagues reading golf 6 without any problems. I do not have this car and can not find it. Is there any problem with Carprog and Golf 5 , Passat b6 or my carprog is damaged ?
Please help because the client is nervous and wants a car back .
hi guys I should change the cluster on vw scirocco 2013 140cv tdi, I have the carprog 8.21 online but from obd can not read the data immo to clone the new cluster, can you give me a hand ?? how can I do ????
Hello,
I would like to hear some feedback from you guys on how good is carprog clone on airbag unit? Any experience and if it worth it or not to get it for airbag unit repairs only.
BR
If It helps you try push the: Thanks and REP
I do the same each time it helps.
SadCriss (24th March, 2019)
Sorry if this has been asked before: any links for a quality clone?
