Results 1 to 15 of 20
    Jul 2015
    venezuela
    Default Digiprog 3 issue in toyota
    hi, i have a digiprog 3 v 4.88 and i want to correct milleage on a toyota hilux and toyota 4runner
    I dont have these models in my digiprog but i have another ones like land cruiser in wich the chip is the same
    so my question is how can i read those chips?
    is there another way to correct mileage?
    thank you
    clusters's Avatar
    Mar 2015
    Canada
    I think his problem is he doesn't know how to read them with Digi, as in connections. If he posts what year we can direct him to a solution.
  3. The Following User Says Thank You to clusters For This Useful Post:
    zckariya70 (28th July, 2015)
    Jul 2015
    venezuela
    Hi, my problem is when I disolder chip 93c66 on the 4runner 2005 cluster and put it on the digiprog I can read the correct mileage and also can write it selecting Hilux c66 or land Cruiser c66 but when I put the cluster back in the car the odometer doesnt roll up. Only the trip meter but the odometer doesnt change
    clusters's Avatar
    Mar 2015
    Canada
    Then you need to post your original file here and have it corrected properly.
  6. The Following User Says Thank You to clusters For This Useful Post:
    saturnojm (1st November, 2016)
    Jul 2015
    venezuela
    I dont have the 4runner model on my digiprog. I hace 4.94 version. I want to know if someone had the same problem or any posible solution
  8. #6
    sida's Avatar
    May 2014
    System32
    Desolder eeprom, read it with programmer and post dump here
  9. The Following User Says Thank You to sida For This Useful Post:
  10. #7
    Jul 2015
    venezuela
    Hi here is the original dump file, it has 176.425 km, I need 92.510 km, is a 2007 toyota 4runner I attach pictures of the cluster and chip too
  11. #8
    Dufner
    Johnner's Avatar
    Éire
    Write in the red bytes into your file
  12. The Following 3 Users Say Thank You to Johnner For This Useful Post:
    clusters (2nd November, 2016), neospeedo (2nd November, 2016), saturnojm (7th November, 2016)
  13. #9
    Jul 2015
    venezuela
    Im sorry can you tell me what software are you using to modify the dump? Its the first time I need to do it this way so I dont have much information about how to.
    Enviado desde mi SM-G900H mediante Tapatalk
  14. #10
    Dufner
    Johnner's Avatar
    Éire
    I'm using a Hex Editor to modify the file mate...I'm assuming rightly or wrongly here that you know what that is....
    Use yours to write the bytes that I've changed into your file and save it...Then write that edited file back to your eeprom.....sorted
  15. #11
    Jul 2015
    venezuela
    Can someone post the modified dump so I can download it directly and write it on the eeprom?
  16. #12
    winaiservice's Avatar
    Oct 2015
    use Isuzu D-max
  17. The Following User Says Thank You to winaiservice For This Useful Post:
  18. #13
    clusters's Avatar
    Mar 2015
    Canada
    Get Hex Editor Neo free edition, it should work fine for you right now.
    Then edit the file like Johnner posted.
    If you're going to keep doing this you will have to learn sometime.
  19. The Following User Says Thank You to clusters For This Useful Post:
  20. #14
    Jul 2015
    venezuela
    Thank you so much. I already downloaded ponyprog and tachosoft and I am right now testing and programing a Renault megane 24c04 chip editing the dump file with my digiprog
  21. #15
    Jul 2015
    venezuela
    I made it succesfully so tomorrow I am calling back the 4runner customer and see what happens with that one. I already edited the dump like Johnner posted
