Here you go.
Hi @ all,
please I need a working FAP off file. I tried volta and ecusafe but not works.
I read the file with V54 Galletto as SID 803A.
Ford_Focus_SID803A_orig.rar
Thanks in advance!
bertonex_19 (30th July, 2015)
Must I disconnect something?
Sorry, but not worked! The car not revs more then 3000...
write back orig file and that interogate ecu with one diagnostic tool,upload here all dtc stored in ecu
Mike
try this file
Abritus AK400 BDM100 BMW-EXPLORER Beprog+ CLIP CarProg ETL ELM324 FVDI IDS J-Link GALLETTO3 SMOK K-SUITE Lexia3 MERCEDESINSTRUMENT MPPSv16 MVP ORANGE5 StarC4 TANGO UPA XprogM X-TOLL ZedBull
Have P1922 dtc...nobody else can help me with fap off file?
Fill the aditive tank with diesel.
or disconnect the aditive module
have you solved it?
after so much headache better to go for the local pro-tuner pay the money and get the car fixed. just my 2 cents.
Chiptuning fanatic - FILE SERVICE 24/7! Chiptuning / Dpf off / Egr off / DTC off / etc.
Bapro 4x4 dyno + SP6
Flex / X17, Autotuner, Bflash, NewGenius, FGTech, HPTuners, BitBox, PCM Flash
Hello bertonex_19, could you fix issue? i'm trying to disable DPF avec empty dpf makinf mil on.
