    Jul 2015
    DE
    Default Galletto 2 dont work
    I test it on XP32bit
    I there any known error ? when i start the eobd2.exe a "error-window" opens ..
    Driver works
    I test some tricks like as start as admin but the same
    I test it also on win 7 64bit but the driver dosent work
    On win 7 32bit the driver works but i have no key to test the programm
    Witch is the best system To work with galletto ?
    carmageddon's Avatar
    Italy
    v48 work on xp and seven 32 bit without problem!
    Babos's Avatar
    Mar 2012
    and win8.1 64x without problem.
    Jul 2015
    DE
    It dont work also on win 7 32bit the prog dont open witout any error message ...
    Where to get V48?
    mihaiservice's Avatar
    http://www.quick-tuning.com
    Quote Originally Posted by gunni88 View Post
    Driver works
    use search button with confidence,already are few post with huge information
    also you can find solution to bypass registration
    Mike
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
    Jul 2015
    DE
    Thanks with great helps from user its get working ..
