Results 1 to 8 of 8
Thread: scenic III
    Default scenic III
    hello.does anyone know how to read a renault scenic III siemens sid307 tricore tc1767?ive tryed with kess by odb but it stops at 96%.i want to try to read it on bentch with galleto or k-tag.realy need help if someone could provide the pinout to do it
    no one can help me?
    Jun 2012
    K-tag is not supported this ecu
    Not sure fgtech
    as far as i can see only Kessv2 with OBD2
    with kess just go to 97%.maybe is because ignition cuts.is there other way to read it?if someone could give the pinout and boot pin i can try read it on the table
    Jun 2012
    isnt there a trick to keep ignition on ? im sure i read before a sequence you have to do, before hand,
    if you could help me i apreciate.
    please realy need a solution to read this ecu.no one knows how?
    hi friends
    anybody found any tool to read this ecu ?
    ktag genium not support it
