Results 1 to 8 of 8
    Default DPF off Q7 0281012772 ecu help needed
    Helo,
    Can somebody please, help with these ecu 0281012772 4L0907401
    EDC16cp34
    Original file attached:
    orig_Flash_0281012772.rar
    Thanks!
    italy
  3. The Following User Says Thank You to giefferacing For This Useful Post:
    tihiuvek (4th August, 2015)
    mihaiservice's Avatar
    http://www.quick-tuning.com
    Quote Originally Posted by [URL="http://www.digital-kaos.co.uk/forums/attachment.php?attachmentid=325146&d=1438635554"
    ATR_Audi_Q7_3_dpf_off_disconnect sensor temp and press diff[/URL]
    if will disconect differential presure sender will go in limp mode after first second !
    Mike
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  5. The Following User Says Thank You to mihaiservice For This Useful Post:
  6. #4
    Thanks for your replay! So does somebody know has to be switch method or emulated?
    I prefer to have everything connected.
    Quote Originally Posted by tihiuvek View Post
    the file made by Mr.Giefferacing are dpf off by switch method,you can used w/o disconect any sensor like diff presure sender or temp sender
    Mike
    Full WinOLS user
  8. The Following User Says Thank You to mihaiservice For This Useful Post:
  9. #6
    So, I tested the file and car is in protected mode.
    I got:
    Address 01: Engine Labels: REDIR FAIL!
    Control Module Part Number: 4L0 910 401 K HW: 4L0 907 401
    Component and/or Version: 3.0L V6TDI G001AG 0030
    Software Coding: 0011779
    Work Shop Code: WSC 03016 425 85930
    VCID: 2A5000F6BAA53F4C
    1 Fault Found
    049921 - Software Incompatibility with Engine Control Module
    U0301 - 003 - Mechanical Failure - MIL ON
    Freeze Frame
    Fault Status: 11100011
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 163116 km
    Time Indication: 0
    Date: 2015.08.04
    Time: 15:30:04
    Freeze Frame
    RPM: 1176 /min
    Torque: 54.6 Nm
    Speed: 40.3 km/h
    Duty Cycle: 1.0 %
    Voltage: 14.21 V
    Bin. Bits: 00101011
    Torque: 167.7 Nm
    Readiness: 0 0 1 1 1
    Does somebody know how to solve these problem?
  10. #7
    what tool you have used to write the file ?
    write back orig file,check if still have that dtc
    Mike
    Full WinOLS user
  11. #8
    disconnect sens press send temp
    solve problem!!!
  12. The Following 2 Users Say Thank You to silvergl For This Useful Post:
    cosmin cl (27th February, 2016), tihiuvek (8th August, 2015)
