Results 1 to 7 of 7
Thread: TMS-1000D
    Nov 2010
    Default TMS-1000D
    Hi guys.
    I've got a Enigma2 box for 28.2E/European satellites at home.
    Recently bought a 1m dish for the motor and the seller kindly threw in a Technomate TMS-1000D. Are these boxes mainly redundant nowadays, or can they still be used for european satellites etc?
    I know they have no ethernet port or even a USB port, but I do have a RS232 cable to connect it to the PC
    Many thanks
    digicon's Avatar
    Jul 2009
    5000 max channel list storage and basically used for FTA only as you correctly put it no ethernet, i am unsure if you can run Vplugserver through RS232 and access some softcam channels.
    Do a Google Search for what information you need
    Sep 2008
    you forgot to say sd not hd,still have my first 2 boxes i bought all those years ago .think null modem cable is just for updating info,was there not patched image or channel data [ keys ] on the old posts as a guide to what you require?
    digicon's Avatar
    Jul 2009
    There is a Patch available 316p dated from 2011 so if it is patched it must be able to run Vplug through the RS232 port
  5. The Following User Says Thank You to digicon For This Useful Post:
    cactikid (7th August, 2015)
  6. #5
    Nov 2010
    Where can I get the patch from and patch loader from? Provided the files are still online..
  7. #6
    digicon's Avatar
    Jul 2009
    here is the patched firmware i would assume you need to patch via RS232
  8. #7
    Nov 2010
    Thats for the TMS1000D right? It says TM1000D on the file name. I've downloaded it anyways, and now just need to find the loader
    Thank very much digicon!
