And how on earth this will give you more power ? )) - Next plan - i will develop a nice green case and wrote on it - Fix any engine wqeird noise. Just plug in to OBD and wait )) the noise will dissapear ))
They sell these for gasoline and disesel engines, Power or ECO, Any car model or brand. BIG LOL , soon they ll make one that will fix any engine damage just by plugging in D: would be the best invention ever just for 7$ D:
Here it goes, step by step, photos and description:
Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
-UPDATE- SO far so bad! ITs v v v hard to open, they glued it to the atmosphere, ******** i m still sudying pcb to see how it works...if it does anything at all. they filled it with components...so far it balances production cost...6 leds, oscilattor, reset button. a big chip, several capacitor and a transistor
bursuc (6th August, 2015), mexanico1971 (15th August, 2015)
But anyway ... that chip should have the capability to change some values or " write " some new data to the ecu or 3'rd option will be to emulate a signal... weird PCB
Yes bursuc...i think its interfering with some signal, i cant find it capable to write ecu...but look at what the instructions say: it does to smth to ECU pre start!
I also desoldering PCB now to send to Xray! and check out CHip numbers!
Update: it seems to have a Flash Microchip
Program Memory Type Flash Program Memory (KB) 3 CPU Speed (MIPS) 5 RAM Bytes 134 Timers 1 x 8-bit Temperature Range (C) -40 to 125 Operating Voltage Range (V) 2 to 5.5 Pin Count 40
K line, and CAn lines are conected to it...it is capable of flashing but its too small to have maps in it....Strange
I m going to test this Tonight in my car and post results.
bursuc (6th August, 2015), kristikapa (7th August, 2015), mexanico1971 (15th August, 2015)
Tested and as expected....no effect on car whatsoever!!!
Is that not because you broke it
Sent from my D6603 using Tapatalk
Too bad... And now also warranty is void because you opened the product. ) Probably when they developed this product they relied on the miraculous power of placebo effect.
work or not ?
Neahh....its a scam...uselsesss!
k1champion (15th August, 2015)
Factorys must eat our money the do something and let us to buy and test is that thing working like they described.
Most of uS buy tools working 50/50 % or working 1 2 days after delivered then blow off, and must pay for another.
did u wait until 200km haha
maybe need to remap your car before use this shi+...
inside forum:ask me about...i will tell you all that i know
make me working for you...i will give you my paypal account
outside forum:
chiptuning,egr,dpf,add blue,dtc,Eu clones
maajkii (4th December, 2017)
It gets hot when plugged in. + no change in engine behaviour and i am affraid to leave it there for 200km, not to damage my engine.
my ecu is also a ~~~~ty KEfico me7.x.x ecu its not the most common out there , i ll test on a easier ecu!
