Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 69
  1. #31
    Sep 2018
    Quote Originally Posted by macako6 View Post
    1. remove only the DPF filter
    2. Remove only the one fuse in the engine compartment
    thank you! does the map also disable the EGR valve?
  2. #32
    macako6's Avatar
    Mar 2015
    Quote Originally Posted by flamb View Post
    No EGR . Onli DPF and SCR
  3. The Following User Says Thank You to macako6 For This Useful Post:
    flamb (14th September, 2018)
  4. #33
    Sep 2018
    write this file and it is enough to remove the 40 A fuse from the adblue control unit (green fuse in the box of the engine).
    Thanks macako6,
    Pls password to open your file
    Best regards.
  5. #34
    macako6's Avatar
    Mar 2015
    Quote Originally Posted by programmeur ecu View Post
    Thanks macako6,
    Best regards.
    now I am not on the PC, when I return I will send it to you. (3 to 4 hours)
  6. The Following User Says Thank You to macako6 For This Useful Post:
    programmeur ecu (12th September, 2018)
  7. #35
    Sep 2018
    Default Thanks
    Thanks, i am waiting to test your solution
    Many thanks
    Regards.
  8. #36
    Sep 2018
    Thanks for password
    i test it but always show in dashboard : Refill ADBLUE 20 KM
    CHECK the picture in attachement IMG_20180912_125550.jpgIMG_20180912_125602.jpg
  9. #37
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    Read ecu eeprom and post dump(93c86 or 66)not possible to disable this massage.try 100 software dpf scr off if you want .(same massage again )I trying and nothing...need reprogramming ecu eeprom.working i try 2-3cx7....
  10. The Following User Says Thank You to vasko For This Useful Post:
    pocinas (17th October, 2020)
  11. #38
    Sep 2016
    I have good solution, I need flash and eep, tested several times.
    FILE SERVICE
  12. #39
    HIC's Avatar
    after filling adblue just disconnect scr module.
    tested working good.
    h.e
  13. #40
    Sep 2018
    Quote Originally Posted by HIC View Post
    h.e
    Where is ?
    The driver seat need to be removed ?
    Thank you
  14. #41
    HIC's Avatar
    Yes
    Remove driver seat,cut carpet and disconnect SCR.
    If you have probl send me your file,
    Tested .
  15. #42
    Sep 2016
    So you not have idea how works this ecu, on this massage scr module off not work..... I works to this solution 2 days so please dont write this bullshit.
    FILE SERVICE
  16. #43
    HIC's Avatar
    Yes
    Tested .
    Your file with FAP off no CS.
    Tested with SCR disconneted
    Don t forget thanks
  17. #44
    Sep 2018
    Don t forget thanks
    ok ok. Is not enough to remove the fuse ?
  18. #45
    Sep 2018
    Ok .
    Attached my original map...
    Someone can help me to remove DPF regeneration and Adblue ?
    Thank's to all
