Fallen (13th February, 2019)
That is what it sounds like to me, and no, it really doesnt sound great if it prevents a dealer ordered key from working. I'm not interested in this solution either.
The past few F series vehicles I've done with Autohex have not had to do any drilling, and I understand the subsequent dealer ordered keys have worked fine. They have definitely required opening the ECU, to get the ISN which is fairly common place. My understanding is that EDC17CP41/45 and MEVD17.2.4/5/8/9 require drilling, but I'm basing that info on the magic motorsport kit for drilling ECUs. Maybe some of them dont require driling with Autohex, I check each vehicle as I quote for it.
Maybe using autotuner on bench mode without opening.
Envoyé de mon LYA-L29 en utilisant Tapatalk
Any feedback about the HexTag on reading writing CAS4 BCM...
Safer than XEP100, VVDI PROG....???
you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
didi_du_93000 (12th March, 2019)
I have see they have make new package. With only HEXTAG for reading and writing cas1 to cas4+.
And only for 450usd!!
If it's 100% safe tool. It's perfect...
I think you either did not watch the video carefully or you did not do any FEM/BDC job by Autohex before, because you always have 3 options: - Have a Key, - Have a DME ISN, - Have Nothing.
We showed in this video a case you don't have a working key, and the DME is lost (example you brought an FEM and a DME from junk yard they are not matched, you want to mount them in water flooded) and you want to mount them in the car. This function can do this for you. In such a case do you think you will order a key from the dealer?
In other cases if you have a working key or a DME ISN, you MUST select the other options to make the key or change the DME or what ever.
what about Porsche BCM , safe for reading and writing ?
"Good luck really.
You spent 3 years to discover that Autohex has a boot mode feature to read/write ISN. I prefer to hear from you after few years."
Still having trouble understanding what your saying champ, maybe use a better translator.
Autohex does have its place in my toolbox, it does some things better then others.
I certainly don't keep it for the support though.
Yes, autohex does have a boot mode, its not part of the main program, its a separate program which is why I didn't know about it.
You seem to think this is an all singing and dancing tool, it's not.
The interface is slow and clunky to use.
To synch a cas/elv it takes a few minutes to get to the correct sub menu hidden away.
I have never been able to find an option to synch the CAS and DME it is so well hidden.
Every time you enter or exit programming/diagnosing it must rescan the entire car, you can't just quickly go to a module that you want to perform a function with.
Also, you failed to comment on why you have to downgrade other modules in the car before you can extract the "secret key" from the FEM.
A process that takes 15-20 mins before it tells you it has failed by the way.
Should we also bring up why I have to keep buying new hardware every year?
I have 3 autohex interfaces that all look exactly the same.
