Page 19 of 26 FirstFirst ... 91415161718192021222324 ... LastLast
Results 271 to 285 of 387
  1. #271
    Fallen's Avatar
    edited by fallen
  2. #272
    Fallen's Avatar
    edited by fallen
  3. #273
    Moderator
    PremierD's Avatar
    Jun 2009
    They are on ~~~~in holiday ....... If you had checked the skype page you would have seen that
  4. The Following 2 Users Say Thank You to PremierD For This Useful Post:
    ghostrider72 (13th August, 2019), kronk92 (13th August, 2019)
  5. #274
    Fallen's Avatar
    edited by fallen
  6. #275
    auto techniek's Avatar
    Mar 2017
    What about programming CAS4/CAS4+(XEP100 series, 5M48H/1N35H) type with OBDII?
    No news yet.
  7. #276
    Sep 2011
    Quote Originally Posted by auto techniek View Post
    No news yet.
    Says in next update. Whenever it will be.
    Išsiųsta naudojantis LYA-L29 Tapatalk 4 Lt
  8. #277
    Dubai
    Hexprog 1.0.8
    New software update released for HexTag for Doing ClONING of ECU in multi brand cars.
    This function is available Free for all users in the year 2019 and only need to pay for the license from the year 2020.
    Users can also see ISN from DME/DDE in HexTag from this update.
    https://www.microtronik.com/info/softwar...-id-100049
  9. The Following User Says Thank You to decno1 For This Useful Post:
    ghostrider72 (10th September, 2019)
  10. #278
    Fallen's Avatar
    Default Todays failure on Autohex
    edited by fallen
  11. #279
    Moderator
    PremierD's Avatar
    Jun 2009
    Maybe they ~~~~in are .................................................. .......................but only when you moan ...
  12. #280
    Fallen's Avatar
    edited by fallen
  13. The Following 2 Users Say Thank You to Fallen For This Useful Post:
    Heedol (13th September, 2019), honda1200 (13th September, 2019)
  14. #281
    I would say second most expensive,Explorer full around 10,000 Euro's
  15. The Following User Says Thank You to joemajdalani For This Useful Post:
    Fallen (15th September, 2019)
  16. #282
    Dubai
    Quote Originally Posted by Fallen View Post
    Todays failure was incorrect ISN reading of a DME from an E87 with all keys lost.
    DME was EDC17CP02
    Autohex read the ISN but gave an incorrect ISN.
    The key programming said it was successful but car did not even crank.
    Tango confirmed the ISN was incorrect.
    The DME was read in the car and on the bench, both times the incorrect ISN was given.
    Problem solved by repairing a damaged key and using that to decrypt the CAS.
    Still waiting on support to contact me from my last issue, I think we are up to 5 weeks now.
    Maybe they are still on holiday...
    if you want technical support from our team you need to contact them either via skype(microtronik@outlook.com) or email.we understand you do before but it was during holidays now without contacting them please don't complaint here.you can see everywhere how our team support customers on various technical issues.
    For the above mentioned issue did you programmed key with autohex and was the key showing in key learning option 1 as YES in slot.by reading your post i believe you already programmed key using autohex and if the isn was wrong in dme autohex will never allow you to program key if all key lost on cas3+.for your technical doubts please contact support in skype for fast reponse.
  17. #283
    Fallen's Avatar
    edited by fallen
  18. #284
    Dubai
    Yes, I read the ECU in the car with no working keys and it gave the ISN.
    I then used that ISN to program a new key using the option of no working keys available.
    The programming went through and Autohex said it was successful but the ELV would not unlock and the keys was not recognised ( the remote did work however).
    I then removed the ECU and read it on the bench and Autohex gave me the same ISN.
    When I tried to use that ISN with Tango, it would not decrypt the CAS, the ISN is invalid.
    I have another car, EXACTLY the same tomorrow and I will try again.
    If I have issues I will contact support by Skype.
    make sure you restore cas in cas firmware option once you finish the job if you downgraded cas .also check from key learning option 1 key showing YES in slot.even after this if the elv fault persist you can give a try for unplug and connect battery negative.yes for tech doubts we really recommend you to go for skype option
  19. #285
    fred77's Avatar
    Jun 2019
    You would think they would want to keep me ~~~~in happy as I seem to be the only active user of this tool but it appears not.
    Their tool keeps ~~~~in up and I will keep telling everybody about it when it does.
    With new AVDI ISN reading released today and Xhorse coming shortly I will be sure to compare all 3 and let people know.
    Autohex is the most expensive BMW only tool but it is far from perfect.
    In fact, it's the only tool I own that has not paid for itself and I have had it for years.
    Thanks for your input Fallen, tho Abrites has failed on 3 F series in a row on spare keys.
    So £1000 wasted update as i see it - which should of gone towards Autohex
    Sure u know but be careful reading ECU ISN without working key if it does flashing, as i lost power and ECU wiped.
    Really backups ideally should be done like CAS. Learned alot that day.
    Don't know how autohex does it - but know nothing 100% safe
