Page 20 of 26 FirstFirst ... 101516171819202122232425 ... LastLast
Results 286 to 300 of 387
  1. #286
    Dubai
    Quote Originally Posted by fred77 View Post
    Thanks for your input Fallen, tho Abrites has failed on 3 F series in a row on spare keys.
    So £1000 wasted update as i see it - which should of gone towards Autohex
    Sure u know but be careful reading ECU ISN without working key if it does flashing, as i lost power and ECU wiped.
    Really backups ideally should be done like CAS. Learned alot that day.
    Don't know how autohex does it - but know nothing 100% safe
    Autohex will give a warning message for the ECU which need ignition for reading ISN.only in that case you need ignition all other ecu's you can read even without ignition.Also even it failed while reading without ignition our Indiv programming feature can get it back alive.
  2. The Following User Says Thank You to decno1 For This Useful Post:
    fred77 (17th September, 2019)
  3. #287
    ghostrider72's Avatar
    Jul 2012
    UK
    Isn with AH you can read within seconds on the bench. No need to open it even. Tested in few and works fine.
  4. The Following User Says Thank You to ghostrider72 For This Useful Post:
    decno1 (23rd September, 2019)
  5. #288
    roth18's Avatar
    US
    Quote Originally Posted by auto techniek View Post
    I m considering buying this tool.
    Is it worthy buying it.
    I have vvdi 2 with BMW package.
    Yes, I have VVDI2 and BMW Explorer and AVDI. Autohex and Hexprog worth buying.
    Best Regards, Roth.
  6. The Following 2 Users Say Thank You to roth18 For This Useful Post:
    fred77 (30th September, 2019), milehighlockdoc (2nd October, 2019)
  7. #289
    Sep 2019
    Default Enable start stop function bmw f20 with autohex
    I done lost keys on a bmw 1 series 2013 with autohex, iv updated programming and coding on fem body and gw, also dme after programming key. The start stop function has stopped working, anybody know how to enable it. Thanks in advance guys.
  8. #290
    Moderator
    PremierD's Avatar
    Jun 2009
    Default Update....
  9. The Following User Says Thank You to PremierD For This Useful Post:
    doctore (11th December, 2019)
  10. #291
    Jul 2012
    UK
    Cas4 works fine with obd. Tested this morning
  11. #292
    Top Poster mexjack's Avatar
    Philippines
    How long did it tale??
    Enviado desde mi SM-G973F mediante Tapatalk
  12. #293
    Jul 2012
    UK
    About 20min ish
  13. #294
    Support told me 10-12min max via obd
  14. #295
    Jul 2012
    UK
    So do it and you will see.
  15. #296
    Which more safe autohex or bm explorer on obd?
  16. #297
    werner5395's Avatar
    May 2008
    Tabor CZ
    Hello have anyone connection plan hextag for CAS1 ? THX
  17. #298
    fred77's Avatar
    Jun 2019
    Hi see the Lite locksmith package -
    Is there any need for missing "ISN Reading from Tricore Ecus by boot mode. "
    on Lost Keys situation?
    See reading ECU on bench using factory mode ? Or is this non-tricore ecus ?
  18. #299
    Oct 2012
    London
    You should be able to retrieve ISN from ECUs on bench as appose to getting full read with ISN incl. in Boot mode. Locksmith lite does not allow modification altering of ISN ect. hence no need for Boot mode.
  19. The Following User Says Thank You to rivalryan For This Useful Post:
    fred77 (25th November, 2019)
  20. #300
    auto techniek's Avatar
    Mar 2017
