Page 23 of 26 FirstFirst ... 13181920212223242526 LastLast
Results 331 to 345 of 387
  1. #331
    Apr 2016
    uk
    Quote Originally Posted by WhiteHatLox View Post
    Either way you have to pay for this subscription to read isn with Hextag or Autohex, right? I was told you can't get around this .. if this I'm false then this is exciting news.
    The subscription for hextag is for cloning ECU's and reading isn but you can read isn with autohex,obd or bench,no problems.
    You have to pay the subscription just for autohex.
    Sent from my MI CC9 Pro Premium Edition using Tapatalk
  2. The Following User Says Thank You to comizelu For This Useful Post:
    WhiteHatLox (13th June, 2020)
  3. #332
    Moderator
    PremierD's Avatar
    Jun 2009
    latest update .........
  4. #333
    fred77's Avatar
    Jun 2019
    Did F10 5 Series spare key today....
    Autohex asked for CAS4 dump and SK code (assume ISN).
    Thought CAS4 could now be done via OBD ??
    This would be really useful for Mini -
    I'm not upset Autohex couldn't do job as already read CAS4 dump - and used VVDI
  5. #334
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by fred77 View Post
    as far as i know the mini never came out with cas4 only cas3
  6. #335
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by jodge View Post
    Mini r CAS4 2014+
  7. The Following User Says Thank You to fred77 For This Useful Post:
    comizelu (16th July, 2020)
  8. #336
    Apr 2016
    uk
    Mini r CAS4 2014+
    Bdc...
  9. The Following User Says Thank You to comizelu For This Useful Post:
    jodge (17th July, 2020)
  10. #337
    ThiagoArgentino's Avatar
    May 2016
    Brazil
    Mini r CAS4 2014+
    BDC sistem
    Solutions in the area of automotive coded keys, all automakers.
  11. The Following User Says Thank You to ThiagoArgentino For This Useful Post:
    fred77 (7th August, 2020)
  12. #338
    can AH do spare key from a F10 through OBD?
    i know have to read ISN from DME.
    but do i need to read cas4 (ews5 aktive) also through BDM or OBD?
  13. The Following User Says Thank You to vageric For This Useful Post:
    fred77 (8th September, 2020)
  14. #339
    fred77's Avatar
    Jun 2019
    Solidarity with Ukraine
  15. #340
    fred77's Avatar
    Jun 2019
    F10 - I had to read with programmer. Done a few but last one i wiped!!
    reading ISN isn't a bad idea to do a key cos maybe more prepared if something does go wrong
    Anyway ordered new CAS4 Module came next day and Autohex coded in seconds with INDIV. Finished with Abrites by sync CAS<>ECU, CAS<>ESL.
    Job done just some £380 outta pocket
  16. #341
    fred77's Avatar
    Jun 2019
    Fantastic tool - did a 2018 mini yesterday AKL.
    Read ECU didn't have to remove from car and upgraded FEm/BCM on bench. didn't pick up a soldering iron, lovely
    tech support is 1st class
  17. The Following User Says Thank You to fred77 For This Useful Post:
    Weasel3 (29th October, 2020)
  18. #342
    SadCriss's Avatar
    At the Garage
    Just a second....
    You're saying that autohex does not have the function of sync CAS<>ECU, CAS<>ESL ????
    I would expect not to need a second tool for doing that... unles there is another reason why you used abrites?
    I mean you buy the tool for bmw that can solve bmw problems......
    If It helps you try push the: Thanks and REP
    I do the same each time it helps.
  19. #343
    May 2016
    Brazil
    I have a defect in the interface, I sent it to Dubai, I have been without the equipment for 15 days, and full of BMW to solve ...
  20. #344
    SadCriss's Avatar
    At the Garage
    Quote Originally Posted by ThiagoArgentino View Post
    I guess because of corona....everything is slow now.
    Looking forward to see how it worked out. Me and one of my friends are interested in buy the full tool.
    Just reading around about it to see how things work whit it...
  21. #345
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by SadCriss View Post
    Just a second....
    Think the sync part is buried in replacement CAS section intended for 2nd-hand programming.
    Support recommended installing dealer software but I didn't have time.
    Is there Key programming features missing off Autohex ?
    Yes - but it seems VERY good on what it does so far.
    Was hoping for CAS2 OBD key programming (* assume missing to confirm)
    and CAS3+ key programming thro OBD to make life easy for Mini programming.
    Also maybe even CAS4 key programming thro OBD like VVDI.
    In fact VVDI does CAS2 OBD key programming well - AVDI just burns a key.
    Do you need more than just Autohex base Locksmith package ? Yes - seems FEM needed updating (which AVDI failed on!!) so guess so
    I'm happy dude - If something F**ks up i can fix + Autohex Support is 1ST CLASS
    I recommend Autohex along with that new VVDI BMW package and reigngold software clone setup on same laptop.
    You'll be able to do anything
  22. The Following User Says Thank You to fred77 For This Useful Post:
    WhiteHatLox (24th November, 2020)
