Decno,
Can Autohex comminicate with a MS45 DME on the bench?
Decno,
If this DME belongs to PT-CAN bus, then you can communicate on bench
Apparently it is on the PT CAN BUS, but I can not get it to comminicate.
I'll keep trying.
Has anyone else ever communicated with an MS45 DME on the bench?
Autohex exhibiting at Automechanika Dubai May 8th - 10th 2016
How warm is it there mate ... factor 50 ?
3 coats of factor 50 and a balaclava![]()
Autohex II BMW software version 1.0.33 is available for Autohex II users.
- Programming Data for E series has been updated in this version
- Coding Data has been updated in this version
- Fixing the wrong value in Key programming of Mechanical Code value (now we show the total 5 digits)
- Fixing issue in coding of AB in some models in E89 series
- Fixing issue of MDV80,MSD81,MSD85,.. issue: sometimes user gets DME ISN, but DME stays in programming mode.
Autohex II BMW software version 1.0.34 is available for Autohex II users.
- FA Manager has been totally changed, users can save FA into files, they can read FAS from files and store in CAS, also FA editor has been added (currently only for testers)
- BMW programming for F series is faster, preparing vehicle for programming has been optimised.
- Fixing a problem of some parts numbers in JBE (E89): Autohex II was unable to program JBE for specific part numbers.
Advanced function in FA manager currently is locked, we will make it available in next release.
acautolocksmiths (30th August, 2016), artkiani (27th August, 2016), decno1 (5th July, 2016), Ebie (11th July, 2016), Pro Diagnostic Solutions (4th July, 2016)
Autohex II BMW software version 1.0.35 is available for Autohex II users:
- FA Manager is available in advanced mode, we wish our valued users to evaluate this feature and come back with some suggestions to enhance this function.
- Improvement in Ecu programming for E and F series.
djollie (12th July, 2016)
what indiv coding can be done on F series?
Is there a list of it?
is bulb checking included?
decno1 (2nd August, 2016)
AutoHex II BMW Software Version 1.0.36
Description: update of programming and coding for E series, fixing an issue in DSC coding in E84, and some more enhancements
More details in our website software news
Are you planing to add an option of software version choice when programming modules in the future or no ??? I know I can contact you but and tell you which software I want but it takes time. I need to do much quicker.
Best Regards, Roth.
decno1 (13th August, 2016)
