Results 1 to 5 of 5
Thread: Vito dpf off
    credoline's Avatar
    Србија
    Default Vito dpf off
    Hello all, i need DPF off for Vito 2.2 CDI, ecu is Bosch 0 281 015 057 A 646 150 67 72.
    Ori file attached, please help only with good and tested solution.
    Thank you
    mihaiservice's Avatar
    http://www.quick-tuning.com
    dpf off with plug disconected from differential presure sender should be ok for you ?
    Mike
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
    credoline's Avatar
    Србија
    I do not know, one member from DK named 16eddi67 was 2 time make to me DPF off on MB EDC16CP31 and that was perfect. Any other solution is not worked okay for me. Now this guy is banned and i can not contact him. I have 3-4 files from him tested to work, but i have not this one. He always told to disconnect connector from temperature sensor and sensor diff. pressure. If you do it the same thing, that would be okay for me.
    Thank you
    hi
    if Mr.16eddi67 have made for you two different file for MB,also you have more than 3-4 file tested by you...also i have give you one dpf off file for reno with edc16cp33 and help with orig file for A6 wich was dtc table deleted by a smart guy.....and many other user from dk have help you with many files in the last couple months...
    i think it time to learn by self if you are working with such kind of job,you have 10 file or maybe 20 dpf off for practice
    Mike
    Full WinOLS user
  5. The Following User Says Thank You to mihaiservice For This Useful Post:
    bobolin4o (12th August, 2015)
    kire106ka's Avatar
    Aug 2012
    MACEDONIA
    Miha best service is free service so many people here have garadge and wait for free files doesan't matter is it good or bad file point is to be free so all money goes in pocket
    IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
  7. The Following User Says Thank You to kire106ka For This Useful Post:
