Page 101 of 551 FirstFirst ... 519196979899100101102103104105106111151201 ... LastLast
Results 1,501 to 1,515 of 8261
  1. #1501
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Can you post pinout from db9 plug I've lost mine, will try by BDM tommorow
  2. #1502
    Quote Originally Posted by CaioW View Post
    BMW m3 2010 with 9287534 cas3++ ID (istap)
    Successfuly downgraded and new key added
    Did you have to update CAS afterwards?
  3. #1503
    Dec 2015
    Quote Originally Posted by Nassreddine84 View Post
    Yes right the car was fine it has already a programmed key i was just adding a key and the key was added successfully and car starts but the only issue is that the dashboard showing the SAFE msg down on the cluster so this is only the problem mates
    Mates no chance to fix the safe msg by vvdi2 ?? Or what could be the alternative solution ?
    NO ADVERTISING PLEASE
  4. #1504
    read the cluster memory and post dump.
    Far better of reading pin and programming with VCDS on older VAG or read cluster and use tango to add to dump.
  5. #1505
    CaioW's Avatar
    Oct 2015
    Everywhere
    Quote Originally Posted by qwojtus View Post
    Nope, device done all by him self
  6. #1506
    Faraday's Avatar
    May 2012
    Quote Originally Posted by LauAlf View Post
    Audi A5, 2008, file transfer error. I BDM and says it does not detect anything.
    Have you fix it? I have same problem on Audi A5 2008
    SAMIC can you check my logs?
  7. #1507
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by Faraday View Post
    you add key or all keys is lost?
  8. #1508
    Dec 2015
    Quote Originally Posted by paul_12345 View Post
    Thanks paul for ur reply do u mean remove cluster and read it on bench or is it possible to read By obdii ?
  9. #1509
    Faraday's Avatar
    May 2012
    Quote Originally Posted by rola1971 View Post
    add key..........
  10. #1510
    Dec 2015
    Hi mates i have got audi RB8 add key situation i tried all the ways not possible to read neither ecu nor cluster what could be the problem is it because of the bad update or what this is the first audi that i try on vvdi2 plz reply thank u
  11. #1511
    Dec 2015
  12. #1512
    Dec 2015
    Always says wait 10 min and after it finishes it starts from the begining
  13. #1513
    ibratex's Avatar
    Jul 2015
    angola
    hello mates , i am willing to buy vvdi2 basic version then next month buy the bmw and etc ...
    my question is does basic function have almost TANGO basic functions ?
    i know tango is perfect for my market in this country but i already have vvdi prog and for me vvdi2 basic is cheaper if it do add transponders by dump as if tango
    i searched for car list for vvdi2 in basic module but didnt find thats why i am asking
    thank you
  14. #1514
    yugo45's Avatar
    What year is that car , I assume is AUDI A4?
    Are you sure that car has MED17?
    I never seen MED17 and RB8 cluster. I my be wrong
  15. #1515
    Dec 2015
    Quote Originally Posted by yugo45 View Post
    Yugo i tried all the systems it is Audi A3 S line i tried the whole selections and nothing reacting with the car tried instrument cluster RB4 RB8 K-line UDS nothing at all i saw lately several thread same car RB8 having same problem need to know if this is a bug from the last update or what??
