I have few customers who said that somebody have adjusted odometer and km in edc 17 car a4 2011. Is that possible without "magic wand " ? All done by obd2. Vvdi 2 can do only in dash. But how they make adjustment in Ecu??? Avdi?
Again with the SAFE msg i got today audi A8 2008 with fingerprint option and also key option same as touareg key kessy system i pulled out the pincode and CS 7 bytes and tries to program the new key by adding key but again the safe comes out and esl opens close car starts and goes off directly plz help mates how to finailzs the job i did now immo off for allowing the customer to drive his car and he is coming back tomorrow any idea how to finalize the job?
NO ADVERTISING PLEASE
Hello Nassreddine84,
If ignition comes on, means you have the correct dealer key.
Not starting means, you still need to program the key with pin.
Check the ammount of Keys!
Check the configuration!
Hi, Afer last update Not able to get Key Info for Bmw 3 series 2008 CAS3+. Had to use another tool bmw keycoder to program key. I had no problems with this CAS version (not updated by dealer) before last update.
Samic, if you read this, please advise if logs are required.
A Happy new year, to Samic, and the Xhorse company!
Nikola123 (29th January, 2017)
ghostrider72 (30th January, 2017)
Rob , I would say his key is good and programmed, but Kessy and ECU are not adopted. If key not programmed on this car , Ignition will never come On.
@Nassreddine84
M8 do not get me wrong what I am going to say, but you need to learn lot of things about VAG cars before you start judge VVDI or any other tool.
I Remember one thing from old guy when I stat this long time ago "Tool do not fix cars , People do this".
amigokola (30th January, 2017), fytfh (30th January, 2017), Nassreddine84 (30th January, 2017), rob h (31st January, 2017)
Nassreddine84 (31st January, 2017)
