Hi to all, danger with VVDI2 , I try make key in BMW e87 cas2 by obd and make key good,but when I want start the car..... the engine not start...... the eeprom of ecu Has been deleted part.... I don't know how ...but make this.....So be careful
did you try sync cas/ecu once you had finished key programming ????
Thanks Kev
Yes I know, I try sync dde-cas with VVDI2 and ista d but nothing, I read eeprom of ecu an is deleted part.....
Have anyone of you guys experience, chip not connected? I'm working on Audi A6 2008, I have the J518 file and I added a key to it but it's saying chip not connected when I try to write it back. I had the same issue when reading it, it's not the soldering. I had the same issue when reading a Porsche module I read it eventually after several tried but now I thinking it's either the cable or the prog.
*** 2017-02-15
*** Require firmware V3.0.0
===== VAG V3.0.3 =====
1. Add BCM2 dump tool, support change immodata in EEPROM dump. Menu->Special Function->BCM2 Dump Tool
2. Bugfix
===== Transponder Programmer V3.0.3 =====
1. Improvement for copy transponder: Support copy Roewe 750
2. Prepare Remote: show Roewe 750, 360, MG3 learn code
3. Immobilizer data tool: Renault Kangoo 2001 93C46 bugfix
4. Bugfix
kevfield (15th February, 2017)
For Audi A6 2008 key shows Learned and dealer key but not lock, car won't start anyone know if this is normal ?
