Page 11 of 551 FirstFirst ... 6789101112131415162161111511 ... LastLast
Results 151 to 165 of 8259
  1. #151
    Jan 2011
    interesting there is alot of problems with the new vvdi 2 i had a similar problem with a 1 series and i was only testing the tool and as i have posted before audi rb4 rb8 doesnt work either its not a good sign when fvdi has to bail it out
  2. #152
    Oct 2015
    I have been using multitool of nearly 2 years and have never had an issue so I would of though vvdi2 would of been just as stable.
  3. #153
    Oct 2015
    Perhaps its a matter of time to get the bugs out? But I agree BMkeys, I assumed it'd be on the same level as multitool
  4. #154
    Apr 2015
    Quote Originally Posted by Bmkeys View Post
    I had a small problem today with a 2005 1 series cas2.
    It was just a spare key job, not lost keys.
    At first I kept getting security login failed, but after a few attempts I could read key info.
    After making the key, I synced cas and ELV no problem, but the car wouldn't start.
    I tried to sync the CAS and DME a few times but it didn't work.
    In the end I had to disconnect the battery for 5 mins and sync with FVDI, then the car started.
    friend,this type need to try several times sync CAS and DME,and re-plug in the key each times then try to start.
  5. The Following User Says Thank You to Samic For This Useful Post:
    phuckyall (12th November, 2018)
  6. #155
    Siham's Avatar
    Jul 2014
    Samic many members also in others forum are complaining about vvdi 2 ,many bugs and many functions does not work .
    In this way you will be like some of your challengers F.....
    Also is not fair to wait customers report to make adjustment on your tool .
    No thank , no HELP .
  7. The Following 2 Users Say Thank You to Siham For This Useful Post:
    DashProg (2nd November, 2015), insomnia2009 (2nd November, 2015)
  8. #156
    Oct 2015
    Quote Originally Posted by Samic View Post
    I tried to sync at least 8 times and it didn't work. I have never had this problem with multitool and FVDI managed to sync it first time.
  9. #157
    Apr 2015
    mate,send log file PM me/on skype,by the way all you tried in the latest V1.0.8 version,right?(in old version maybe have this problem)
  10. #158
    Oct 2015
    I have the latest version installed.
    I will see if I can find the log file.
  11. #159
    DK Veteran labusas's Avatar
    Nov 2010
    HI Samic
    Please look at the logs for failed BMW 3 series, cas 3+ encrypted. I tried 64 times, I tried with an eeprom file and 64 times, failed to make key. Igntion was ON, keyless worked but no start.
  12. #160
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by Siham View Post
    where have you hear this ?
    send me link please
  13. #161
    Oct 2015
    I had another issue today.
    Attempted to add another key to a 2003 Audi A4.
    It pulled the pin code ok, but when I tried to learn 2 keys, the immo light just started flashing really fast and not add any keys.
    It would learn 1 key fine, just not 2
    I had to use Chinese vag login tool to add both keys.
  14. #162
    Oct 2015
    Is there a list anywhere for the cars that vvdi2 can program via obd2?
    It's confusing to find any confirmation for all the cars this can program. there is even mention of MB IR keys, but not a lot of explanation
  15. The Following User Says Thank You to thebigk For This Useful Post:
    bigkey (8th January, 2017)
  16. #163
    Can somebody confirm which Porsche models this tool covers? Is the Porsche section the Cayenne (that used to be included with the VAG) or is it for the 9x6/9x7/9x1??
  17. #164
    Nov 2010
    Quote Originally Posted by dmp View Post
    Only Cayenne/Touareg
  18. The Following User Says Thank You to labusas For This Useful Post:
    dmp (3rd November, 2015)
  19. #165
    Maartinj's Avatar
    Nov 2010
    Guys. once again :
    If any of YOU discover an issue with some options and want to complain, please post a LOG from that operation which NOT work , it will help to fix it
    Every time when you open VVDI/ VVDI2 new LOG is create, so please LOG will contain only a issue.
    Thx
  20. The Following 3 Users Say Thank You to Maartinj For This Useful Post:
    Samic (4th November, 2015), thebigk (3rd November, 2015), vavrich (8th December, 2021)
