Page 12 of 548 FirstFirst ... 278910111213141516172262112512 ... LastLast
Results 166 to 180 of 8217
  1. #166
    DK Veteran labusas's Avatar
    Nov 2010
    Hi Maartinj, I posted my logs about bmw couple posts above. can you help?
  2. #167
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by labusas View Post
    I am sure SAMIC already did that , he is closer to engineers department, but I will also forward this .
  3. #168
    Jan 2011
    here is another log cant connect to comfort module in vw 6 year 2011 im starting to get annoyed with this tool only simple thing but still its not good
  4. #169
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by insomnia2009 View Post
    what address you try to connect ?
  5. The Following User Says Thank You to Maartinj For This Useful Post:
    dustin2014 (4th November, 2015)
  6. #170
    Jan 2011
    as far as im aware its autodetect
  7. #171
    Oct 2015
    Your not the only one that is getting annoyed. After paying $2400 for this tool, it is causing me more problems than it solves.
    I'm having to constantly revert back to vcds and FVDI.
  8. The Following 4 Users Say Thank You to Bmkeys For This Useful Post:
    dustin2014 (4th November, 2015), insomnia2009 (4th November, 2015), lion0304 (5th November, 2015), Siham (4th November, 2015)
  9. #172
    Nov 2010
    Had no problem with precoding and programmin 2 keys for 2014 Jetta today. Worked well.
  10. #173
    Jun 2014
    Quote Originally Posted by Bmkeys View Post
    I feel the same way too.
  11. #174
    Jan 2011
    i didnt have problem coding to start but wanted to code remote and wont connect to comfort module
  12. #175
    Apr 2015
    HI Samic
    Please look at the logs for failed BMW 3 series, cas 3+ encrypted. I tried 64 times, I tried with an eeprom file and 64 times, failed to make key. Igntion was ON, keyless worked but no start.
    friend,this situation may occur but infrequent.you can get ISN via programmer,then do it.
  13. #176
    Apr 2015
    mate,after you start the car,wait a while click"diagnostic"select "address09-Central Electric"then try again.
  14. #177
    Jan 2011
    will try that today a report
  15. #178
    Nov 2010
    Hi, Samic. How do I get ISN via programmer? Do you mean tricore in ECU?
  16. #179
    Oct 2015
    Yes labusas, you need something like smok, vvdi prog, or autohex ii there is others as well to get the isn in this situation.
  17. #180
    Siham's Avatar
    Jul 2014
    What i understood is that both vvdiprog and vvdi2 can get isn, right?
    Also vvdi2 can get it buy flash reading or by obd?
    Please Samic give us explications please .
    No thank , no HELP .
