it was dealer key - I even tried to program 1 key with the working key that would start the car and it would not work (to clear out all of the other ones)
I was able to successfully make 3 dealer keys but only one would add to the immo. There were 4 programmed keys when I started (so it's not like all the slots were full)
dustin2014 (24th December, 2015), insomnia2009 (24th December, 2015)
Skoda Octavia 2006: got CS & PIN , programmed key fine, but not remote programming.
VW passat. B5: Pulled PIN, programmed key, corrected miles.
VW Passat B6 2009: Pulled PIN but couldn't get 6 bytes CS, needed comfort dump.
VW Transporter T5 2006 : Pulled PIN Programmed key, no remote programming.
VW LT35 2003 : Correct miles failed.
Audi A4 2006 : mileage correction success .
Audi A6 2003: Mileage correction fail. car not start. remove battery terminal. car start.
Atex31 (24th December, 2015), insomnia2009 (24th December, 2015), jareckii (3rd January, 2016), lidons (24th December, 2015), Siham (24th December, 2015)
Went to the car again today, the key learn function would not work. Had to use my datasmart to clear all of the keys and then I was able to successfully add the new keys via vvdi2. Could not get it into learn function, ensured no lock time and tried multiple times but nothing, only the add key function.
Audi BCM2 add spare key by obd worked fine.
Can repair dEF error in RB4 and RB8 audi A4 clusters with this tool?
tajfun211 (29th December, 2015)
