Page 353 of 553 FirstFirst ... 253303343348349350351352353354355356357358363403453 ... LastLast
Results 5,281 to 5,295 of 8287
  1. #5281
    super jumbe's Avatar
    Livingstone
    Quote Originally Posted by rob h View Post
    Get full.
    Bcm2, and BMW Will pay for Them selves in time.
    And full includeds mqb, edc17, med17 tool.
    Not the id48 cloning.
    Upgrading later on is possible, and will cost more.
    Nice 1 mate you got link to good company you would recommend thanks.
  2. #5282
    Oct 2018
    Im looking to buy vvdi2 just for BMW i see something about that it needs Token for cloning does this mean i would only need to buy Token if i want to do INS or cloning ?
  3. #5283
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by Impac4000 View Post
    No tokens need for VVDi BMW
    Only tokens for some VAG options
  4. #5284
    Oct 2018
    And can VVDI2 Read and write INS ?
  5. #5285
    Apr 2016
    it is possible to learn audi prepaired by dealer key without bcm2 eeprom?
  6. #5286
    Quote Originally Posted by K1nd3r View Post
    No, You need dump.
    Wysłane z iPhone za pomocą Tapatalk
  7. #5287
    Apr 2016
    Has anyone succeed maked key for audi a6/a7/a8/touareg with bcm2? I always receive error when reading internal can data
  8. #5288
    jodge's Avatar
    Mar 2017
    Yes, but after 2014 the bcm2 is crypted
  9. #5289
    Apr 2016
    Quote Originally Posted by jodge View Post
    forgot to write, all keys lost
  10. #5290
    Jan 2016
    Hi Guys..
    Having trouble adding key to Touareg 7L. Everything is ok till learning procedure.
    When learning one key (mine or original from car) all is ok. VVDI2 wants to take out key 2 times.
    When I try to learn 2 keys I must take out each key 2 times also ??
    I am a bit confused...
  11. #5291
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Dash not show 0/2 is show follow screen till 2/2 and push ok
    If not show .than try both methods
    Each key 1 time etc.
  12. #5292
    drugowaz's Avatar
    Mar 2015
    Lithuania
    When you find out tell me solution i had same problem.
    Only 1 key works after learn. Ori or new.
  13. #5293
    Jan 2016
    VVDI2 info during key learning is very confusing. It tell you to switch ignition on/of and take out the key but it doesnt tell you which key and how many times.
    In this model on dash there is no 0-0 during key programming. I'll have this car at monday so I'll let you know. Maybe someone here did spare one with success and will share knowledge ??
  14. The Following 2 Users Say Thank You to amigokola For This Useful Post:
    drugowaz (14th December, 2018), rola1971 (14th December, 2018)
  15. #5294
    damih's Avatar
    france
    Quote Originally Posted by amigokola View Post
    I have programmed more than 4 key all ok you have a bad key for sure chinese key have a low signal i have get a same problem like you with bad key
  16. #5295
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Noncence.....
