Page 365 of 553 FirstFirst ... 265315355360361362363364365366367368369370375415465 ... LastLast
Results 5,461 to 5,475 of 8282
  1. #5461
    Aug 2015
    a). Support change MQB key ID(support GEKO online),require use VVDI proximity remote
    b). Support save synchronize data when make key with working key
    c). Support make dealer key with immo data and synchronize data while all key lost
    Can you please give more Info about it.
    'require use VVDI proximity' We need vvdi key for clone the IDs?
    Which synchron data is meant?
    Will it also be possible to copy the component protection bytes.
    Thx
  2. The Following User Says Thank You to offsystem For This Useful Post:
    u.s (7th January, 2019)
  3. #5462
    Nov 2012
    " 5. Immobilizer data tool: Asia->Isuzu->SX4 TC1762 bugfix"
    This would be Suzuki.
    Or Isuzuki to make peace. ) .
  4. #5463
    Sep 2016
    GB
    You mean read eeprom. Safe data. Then change eeprom and write back. Then dash back in car. Read and load orig. Eeprom file and then all ok?
  5. #5464
    Sep 2016
    GB
    Drugowas - You mean read eeprom. Safe data. Then change eeprom and write back. Then dash back in car. Read and load orig. Eeprom file and then all ok?[/QUOTE]
  6. #5465
    Sep 2016
    GB
    In what menu load dump in vvdi2?
  7. #5466
    Quote Originally Posted by offsystem View Post
    Thx
    @Samic
    As this user has asked, please try to give more info or better explanation of what the new features are or how to use them.
    You must have tested them before release, so screenshots during your testing can be used to update the user manual.
    The user manual updates are long over due.
  8. The Following User Says Thank You to u.s For This Useful Post:
    offsystem (7th January, 2019)
  9. #5467
    Codekuba's Avatar
    Aug 2018
    I have problem with VVDI2 6.1.0
    Transponder programmer --->> ready remote ---> proximity remote and is only "mitsubishi outlander 2309" and nothing more....
    VVDI2 6.0.0 it was the same
    base remote 212
    HELP == thanks + reputation
  10. #5468
    With these new updates and the release of the VVDI prox remotes will we be able to add VW prox key-less go remotes? I know it can do it right now but nobody sells these unlocked oem remotes.
  11. #5469
    Jul 2018
    CHINA
    Thx
    yes you need ues vvdi MQB key and you can modify the id as you want ,you can ask the dealer about the infos , that version no release copy ,so ,you can programs the key with vvdi 2 , about the synchronize , which is means you can read the data from original key ,and right now we support to write the data to vvdi MQB key , after write , just do the key learn ,the key will be working
  12. The Following 2 Users Say Thank You to PerryZhang For This Useful Post:
    offsystem (8th January, 2019), ramiz auto lock (8th January, 2019)
  13. #5470
    Jul 2018
    CHINA
    Quote Originally Posted by keysmith View Post
    yes , you can add key-less go or not ,both fine , and the MQB KEY of vvdi , pls check with dealers about the info
  14. The Following User Says Thank You to PerryZhang For This Useful Post:
    keysmith (8th January, 2019)
  15. #5471
    Dec 2016
    Quote Originally Posted by sdnatlst View Post
    deciding between this VVDI 2 bmw commander, and CGDI bmw,,, i just want to do CAS3 by OBD,
    any failures for VVDI 2 for this? downgrading CAS3+ etc all working fine ?
    500€ for one & 1200 for VVDI2 , just for BMW obd2 job = CGDI bmw
  16. The Following User Says Thank You to TERMINATOR1000 For This Useful Post:
    sniegavirs (8th January, 2019)
  17. #5472
    sniegavirs's Avatar
    Mar 2017
    Latvia
    At the moment CGDI BMW is way past VVDI2
  18. The Following User Says Thank You to sniegavirs For This Useful Post:
    sdnatlst (8th January, 2019)
  19. #5473
    ruffles1986's Avatar
    Sep 2011
    In the Garage
  20. #5474
    Oct 2016
    France
    hi,can somebody explain how to make key on the vw passat b6 2006? i have 1 working key and 1 which i want adapt,i never did b6 so littel scered)
  21. #5475
    Oct 2016
    France
    omg what happend,i did upgrade vvdi2 to last version v6.1.0 now it can not find vvdi,what is wrogn with it??vvdi.jpg
