Page 377 of 553 FirstFirst ... 277327367372373374375376377378379380381382387427477 ... LastLast
Results 5,641 to 5,655 of 8287
  1. #5641
    Jan 2016
    Normal BCM2 system. Should work with original unlocked key.
    Did a lot of A6, A4 and it is the same.
    Anyone tried a8 2012 add key?
    Have a customer wants a second key..
  2. The Following User Says Thank You to amigokola For This Useful Post:
    comizelu (11th February, 2019)
  3. #5642
    Oct 2015
    I have problems making new transponder for Vito 68HC, not work. Here is file from immobox 4L52H and my VVDI2 can't do new transponder.
  4. #5643
    Mar 2017
    passat b8 2018 no work . no read eeprom and immodata
  5. #5644
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by driver35 View Post
    save LOG and send to tech support over your seller
  6. #5645
    Jan 2017
    Hello please help asap, add key bmw fem 320i 2012, after program done and return priginal file, relays started clicking and lost communication on bench and even when i connect to the car.. now fem is dead.. any advice?
  7. The Following User Says Thank You to gilahish For This Useful Post:
    sniegavirs (11th February, 2019)
  8. #5646
    asmn's Avatar
    Aug 2010
    HI All
    Just tried do Audi A4 2015 not working as well. Can't read BCM2 security access success but file length wrong.
    Best regards.
  9. #5647
    Sep 2016
    Quote Originally Posted by asmn View Post
    HI All
    Best regards.
    Stop dreaming. Even some 2013 are already locked.
  10. #5648
    Feb 2014
    Just did Porsche Cayenne 2011 with 2M25J in the BCM.
    Some people were wondering if VVDI2 can do it, here in this thread - well, it can.
    Actually most work is done with VVDIProg (read/write) and only preparing of the (dealer)key and generating the new dump with the new key is done with the VVDI2.
    All is done by EEPROM soldering.
    Soldering must be done very carefully and in high quality - these motorolas are extremely sensitive. Also 12V must be attached.
  11. The Following 13 Users Say Thank You to autoTkey For This Useful Post:
    Buzztek (14th February, 2019), dooshan (13th February, 2019), honda1200 (12th February, 2019), Jobeso66 (12th February, 2019), Maartinj (13th February, 2019), madaxe (12th February, 2019), milehighlockdoc (12th February, 2019), ramiz auto lock (15th February, 2019), RG550 (13th February, 2019), sniegavirs (12th February, 2019), u.s (13th February, 2019), vasa (13th February, 2019), yugo45 (14th February, 2019)
  12. #5649
    Sep 2017
    Quote Originally Posted by autoTkey View Post
    Cool thanks for sharing
  13. #5650
    Jun 2012
    Thanks for sharing...
  14. #5651
    Apr 2016
    maybe someone had same situation, audi with j518 ezs all key lost, after key programming, ezs/elv unlocks, remote works, but no ignition, error in ezs "terminal 15", nad strange, on dash after key learning title 1/1 stuck
  15. #5652
    In EEP
    Quote Originally Posted by K1nd3r View Post
    Try to conect obd pin 1 and 16 clear all dtc. You've been open Elv check switch contact
  16. #5653
    Apr 2016
    ignition switch is under the white wheel/roller?
  17. #5654
    Sep 2016
    Dear.BMW-If all keys lost.CAS1,2,3 make keys by OBD?
  18. #5655
    asmn's Avatar
    Aug 2010
    Yes can be done....
  19. The Following User Says Thank You to asmn For This Useful Post:
    lock66 (14th February, 2019)
