Page 378 of 553 FirstFirst ... 278328368373374375376377378379380381382383388428478 ... LastLast
Results 5,656 to 5,670 of 8282
  1. #5656
    Jan 2016
    Hi Guys.
    Few questions:
    I have client with stolen dashboard 8H0920930J Audi A4 8H BDG.
    1. Is it 7bytes or 12 bytes dash ??
    2. Does VVDI2 do IMMO OFF in this 2.5 TDI by OBD without ECU dismount ??
    3. What is the adaptation procedure of RB8 when there is no original dashboard ?? (manual data write ??)
  2. #5657
    Faraday's Avatar
    May 2012
    The dark side of the moon
    What year? AfAIK 2.5tdi and 1.8t is 7bytes
  3. #5658
    Jan 2016
    Model year 2006.
  4. #5659
    Sep 2016
    You cant disable immo in 2.5tdi after 06/2002 via e2. Get such dash with immo3, write CS from ecu and generate transponder with proper tool. I dont think immo3 will use any macs.
  5. #5660
    LauAlf's Avatar
    Quote Originally Posted by driver35 View Post
    passat b8 2018 no work . no read eeprom and immodata
    Not is VDO. Is JC.
    Enviado do meu SM-G935F através do Tapatalk
  6. #5661
    Jan 2016
    Got info that I can disable immo by OBD2 in this 2.5TDI...
    geso705 this is RB8 dash but it can be 7 byte so IMMO3.5.
    I dont think it would work without immo off only by writing CS to dash...
    Quote Originally Posted by qeso705 View Post
  7. #5662
    Sep 2016
    Ecu is similar to a6 4b, still edc15 which is reason why they put this unique dash. What you have to lose?
  8. The Following User Says Thank You to qeso705 For This Useful Post:
    amigokola (16th February, 2019)
  9. #5663
    DK Veteran elmassioui's Avatar
    Dec 2010
    Hello. If any one can give some help about my case with FEM when i push programming FEM BDC...
    THANK YOU
    Envoyé de mon LLD-L31 en utilisant Tapatalk
  10. #5664
    spychu14's Avatar
    May 2011
    POLAND
    Anyone did MINI cooper paceman with "CAS3++(ISTAP)" OBD by VVDI2 ?
    VAG
  11. #5665
    I did, no problems.
  12. #5666
    spychu14's Avatar
    May 2011
    POLAND
    Did you have to reflash CAS module ? Is it safe ?
    VAG
  13. #5667
    ghostrider72's Avatar
    Jul 2012
    UK
    Read it with Prog. Much safer
  14. #5668
    Faraday's Avatar
    May 2012
    If cas3++ always do backup.
  15. #5669
    spychu14's Avatar
    May 2011
    POLAND
    f..k - cas is under front dashboard...
    VAG
  16. #5670
    Jul 2012
    UK
    And? Better spend more time now than later fixing it
