Page 386 of 548 FirstFirst ... 286336376381382383384385386387388389390391396436486 ... LastLast
Results 5,776 to 5,790 of 8219
  1. #5776
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by exe123 View Post
    And? The menu I have pointed out is for the OLD kessy system from VDO/Conti with Hitag2 key...
    old kessy to 2008 have 93c86 eeprom
    read eeprom and make key ,it easy
  2. #5777
    Sep 2013
    I did key with transponder pcf7935 it’s easy but I need keyless function to work. That’s why I need to renew key which is contained pcf7943as. And also need to change Vin. But the problem is Elv. Any solution except buying new parts?
  3. #5778
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by adrian1914 View Post
    i dont see in 2004 year audi A8 keyless.first is for my
  4. #5779
    VVDi2 FEM test
    For the test 1 FEM concerned everything went well with the VVDI2 and VVDi Prog.
    Have now got 2 more FEM to adjust and proceeded exactly to VVDI 2 and does not work. It comes to errors after Step 4. Other FEM just like that.
    VVDI2 test with BMW fails here everything.
    VVDI2 support answers after 5 days !!!
    VVDI2 could improve a lot with the help of the users and Live Support Team Viewer.
    I do not want to spoil VVDI2 but I want to improve it.
    And that is only possible if you as a customer writes the problems.
    But from vvdi2 there are no updates to BMW CAS3 + and FEM works only conditionally.
    I am looking for VVDI 2 support to test FEM and CAS3 + !!!
    Team Viewer available !!!
  5. #5780
    aem's Avatar
    Jun 2014
    snowboarding on the mountain
    how u use it with fem platform or via obd on car?
    FILE SERVICE
    REMAP+ dpf-egr-vsa-scr-lambda...cars/buses/agriculture
    Genuine WinOLS user
  6. #5781
    Quote Originally Posted by aem View Post
    I use a test cable and work it at home.
    I can read keys.
    I read the encoding
    With VVDI XPROG, I read EEprom.
    With VVDI2 the EEprom is edited and I play it again.
    The programming also works everything.
    After the original EEprom is played and you execute step 4, the error comes with the hex.
  7. #5782
    Oct 2016
    France
    hi,can somebody give me link to download last version vvdi2? i did reinstall windows
  8. #5783
    Quote Originally Posted by barho67 View Post
    https://www.mk3.com/downloads
  9. #5784
    Apr 2016
    how page1 of TRPWS21 should be prepared for obd programming of toyota rav4 2016 H chip ?
  10. #5785
    So FEM can now be read and edited with VVDI2. The whole thing was not because the data was too new. Then I downgraded both FEM with ESYS and again tested the whole thing with VVDI2.
    And now you can edit it.
    Problem is now only with the start / stop simulation button, the green LED briefly but then off again. The key is also recognized by VVDI2 but no ignition terminal 15 is released.
  11. #5786
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Today VVDI2 disappointed me again! Customer came to me with CAS3 unit with 2 keys. 1 OEM and 1 china that I programmed to that car 2 years ago with VVDI2. Now he has swapped different engine with its own CAS system so this CAS he brought is not needed anymore so he wanted to unlock the old CAS unit keys so we could program them to new cas. I said NO PROBLEM it should be 10min job to unlock them. So tried it with KeyInfoFile method, it starts triyng with each key slot and when it gets to actual keys slot it shows error - Can't detect transponder.... I thought some glitch maybe and tried with other key! Same error... Then i read eeprom from CAS with VVDI Prog and tried to unlock keys with CAS3+ EEPROM method! SAME ERROR!!!!! What the hell..............?????
  12. #5787
    yugo45's Avatar
    Hello.
    I need unlock hitag pcf7935as from a8 2004. I have ori dump from Kessy.
    Any update in future for this in vvdi2??
    You need CS and Pin for this or just load Kessy eeprom file , then use Unlock 7946 in Key program menu for A8, Touareg . I have done it many times. After that if is remote key you need to write Remote bytes in Key transponder menu. I never try 7943 but it does not hurt to try.
    Or you can get new chip and change it.
  13. #5788
    yugo45's Avatar
    Yes, Key learn -> 4th Immobilizer System VW/Skoda/Seat -> Touareg/Phaeton/A8/Cayenne/Bentley Immobilizer
    Key needs to be new and not locked. Used keys cannot be reused!
    If you have New Kessy and read with VVDI Prog , you can get CS and pin in that menu. And program key.
  14. #5789
    Sep 2013
    Quote Originally Posted by yugo45 View Post
    You need CS for this , then use Unlock 7946 in Key program menu for A8, Tiguan . I have done it many times. After that if is remote key you need to write Remote bytes in Key transponder menu.
    Thx for reply. I have tried to do this way but it won’t work.
    Also yesterday I try read cs and pin from Passat b7 2014 it says success but cs and pin was wrong.
  15. #5790
    yugo45's Avatar
    You can try with new chip and change it. I have done in 7946 and worked good .
