Page 404 of 553 FirstFirst ... 304354394399400401402403404405406407408409414454504 ... LastLast
Results 6,046 to 6,060 of 8286
  1. #6046
    Member zolee33's Avatar
    Mar 2016
    Hungary
    Audi A3 8P 2005 BKC, i want to change the cluster, but vvdi2 wouldnt read the old IC.
    Have any chance to support this cluster in future?
  2. #6047
    Oct 2016
    France
    Quote Originally Posted by super jumbe View Post
    Any information about Peugeot / Citroen any one tested vvdi2 reading pin and key programming does this work 100%.....
    hi,i did read pin from 2-3 psa cars with working key,and its working god but i dont think its will work for every cars
  3. #6048
    rob h's Avatar
    May 2011
    Have you tried special function menu, k-line?
    Quote Originally Posted by zolee33 View Post
  4. #6049
    It's 8P VDO dash with Fujitsu. VVDI does not support them. Read Immodata from ECU (CS, Login, MAC and immo id) get 7th byte from key and transfer to new dash.
  5. #6050
    Mar 2016
    Hungary
    No, will try and report
  6. #6051
    Mar 2016
    Hungary
    Quote Originally Posted by exe123 View Post
    Thanks your reply. I got all data what i need.
    From ECU: CS 6 byte, PIN, MAC, VIN, ImmoID, powerclass
    From keys: transponder ID and CS 7 byte
    After transferred to the new dash, all ok on bench, no SAFE
    Installed to the car, SAFE on dash.
    What about Status and Config? I tried to play with it but no success.
  7. #6052
    Mar 2016
    Hungary
    I did a short video, no immo fault, strange
  8. #6053
    Autohex and Yanhua tool have updated to 'Read and write N20/N55/N13 ISN on bench without need to open the DME shell.'
    Hopefully VVDI2 will get this update too soon and not just the new VVDI BMW Tool
  9. The Following 2 Users Say Thank You to u.s For This Useful Post:
    p1et (21st May, 2019), whiskeyman (22nd May, 2019)
  10. #6054
    XHORSE WHAT HAVE YOU DONE!
    I can no longer see the ISN from the CAS eprom. Up until that last few updates whenever I backed up the CAS eprom it always displayed the ISN under the "File Make Key" option but not anymore. EVEN bins I pulled months ago and saved on my computer that I could see the ISN back then don't show the ISN today & ECU/CAS ISN stopped displaying the ISN. Xhorse what have you done within these last few updates?
  11. The Following User Says Thank You to keysmith For This Useful Post:
    keymax (1st June, 2019)
  12. #6055
    In EEP
    Quote Originally Posted by jokir View Post
    VVDI2 tool Can read and save S-KEY from dashboard ?
    thans
    No vvdi2 cant
  13. #6056
    Attachment 621552
    Attachment 621554
    Attachment 621556
    If you disconnect ECU, does SAFE go away and you get mileage instead?
    If so, I guess it is related to powerclass or MAC.
    Upload your immoblock from dash and EDC16 eeprom dump or data.
  14. #6057
    Quote Originally Posted by keysmith View Post
    Removing features from VVDI2 to add to VVDI BMW Tool perhaps?
    This is something we would expect from OBDSTAR and not Xhorse!
    Any one from Xhorse care to respond?
  15. #6058
    Mar 2016
    Hungary
    Without ECU no SAFE on dash.
    Later i'll upload ecu confdata and immoblock from dash.
  16. #6059
    Sep 2013
    Default VVDI 2 new tool arrived
    Hello. Audi A8 2005. Mechanik changed els,kessy and key from donor car. The problem was CP. I did online then was all ok. But now customer want have or VIN in the car. So I put ori els, key and did kessy and Ecu adaptation with vvdi2. Car started but CP on module which I can’t do online. I get error : faz1224e is mean immobiliser not coded correctly to entry and start system.
  17. #6060
    2012 Audi Q5 AKL worked via OBD2
