Page 409 of 553 FirstFirst ... 309359399404405406407408409410411412413414419459509 ... LastLast
Results 6,121 to 6,135 of 8286
  1. #6121
    Sep 2016
    2016 peugeot 208 UK model, vvdi2 read pin by OBD with working key 1 min, then failed to connect to immo to program spare key, key programmed with mvp!
  2. #6122
    Jun 2012
    Quote Originally Posted by honda1200 View Post
    Friend,go back to menu,program keys,select vehicle and work ok.Or just wait 2min. and try.
  3. The Following User Says Thank You to Oras For This Useful Post:
    fytfh (13th June, 2019)
  4. #6123
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    is this possible with vvdi2
    swap audi a3 2015 faulty cluster
    with used cluster
    maybe a big ask
  5. #6124
    didi_du_93000's Avatar
    France Paris
    Geko is your solution.
    With Tapatalk
  6. #6125
    Sep 2016
    Quote Originally Posted by whiskeyman View Post
    with used cluster
    maybe a big ask
    being an mbq platform, I don't think it can be done with vvdi2.
    It's possible on Non MQB for now. If xhorse develop some way of doing all key lost on MQB, I guess it will be doable then.
    Sent from my Redmi Note 7 using Tapatalk
  7. #6126
    Usa
    I bought from China kabel comes from shenzeng and is a big ~~~~ing !!!
    VVDI2 is also developed here !!!
    China clont what and do something new which does not work !!!!
    At CAS3 + are apparently the Russians in front of the work with BMW Explorer!
  8. #6127
    Samic,any news for update dash Jonson Control G7 for make spare key?
  9. The Following User Says Thank You to Brat For This Useful Post:
    p1et (17th June, 2019)
  10. #6128
    RG550's Avatar
    Oct 2017
    Any news for FCA group?
  11. #6129
    Feb 2014
    No news here. All efforts are redirected to their new tablet. But I'm just guessing!
  12. #6130
    What tablet?
  13. #6131
    sdnatlst's Avatar
    Aug 2011
    England
    hi all, i have an audi a6 - 2006 year spare remote key to do,
    what is safest way to do this, with vvdi2? is there a guide, it is using 8E chip i believe, so cloning is not an option
    Thanks!
    Tools owned -
  14. #6132
    Apr 2016
    uk
    Quote Originally Posted by sdnatlst View Post
    Thanks!
    Just choose a6,autodetect pin &cs.make dealer key and learn key.dont need 7th byte.
    Yes,8e tp in circuit.remote will work automatically.
  15. #6133
    sdnatlst's Avatar
    Aug 2011
    England
    thankyou sir, i have a 8e audi key from china, im not sure the TP will be integrated to circuit because it seems to be a generated remote by some chinese tool, maybe i will need to learn it seperately.
    i was just checking it was safe, and i did not need to backup any ABS coding or similar
    Tools owned -
  16. #6134
    Nov 2012
    Quote Originally Posted by autoTkey View Post
    99%.
    In the past 1 year, the updates where just a kind of time staling.
    Nothing new. They do not correct the mistakes, they do not add notyng new.
    Time will tell .
  17. The Following User Says Thank You to dorofteius For This Useful Post:
    super jumbe (18th June, 2019)
  18. #6135
    Apr 2016
    uk
    What key are you talking about? 8e?
    If is remote 8e,id48,434mhz is for Audi A4 2005-2008.
    If is 4f with tp 8e in circuit,868mhz this is what you need.
    Remote cannot be programmed manually or by diagnostically.
