Page 410 of 553 FirstFirst ... 310360400405406407408409410411412413414415420460510 ... LastLast
Results 6,136 to 6,150 of 8287
  1. #6136
    drugowaz's Avatar
    Mar 2015
    Lithuania
    If anyone need ori virgin 8e megamos 868mhz remote keys contact pm.
  2. #6137
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    had a head scratcher today
    wonder if anyone can shed some light
    audi a3 2009
    micronas
    read 24c32
    put in service mode
    back to car press load file and point to original dump
    then asked for dealer key and wait 10 mins
    failed to read immo data
    never had that before
    can anyone shed some light on this please
  3. #6138
    sdnatlst's Avatar
    Aug 2011
    England
    What key are you talking about? 8e?
    If is remote 8e,id48,434mhz is for Audi A4 2005-2008.
    If is 4f with tp 8e in circuit,868mhz this is what you need.
    Remote cannot be programmed manually or by diagnostically.
    hi, i checked my key stock, i do have 8E chip audi key, but it is 433mhz and has seperate 8E TP glass chip inside and seperate remote board, what would this remote be for?
    i have ordered A6 868mhz key
    Tools owned -
  4. #6139
    Oct 2016
    France
    hi,can somebody tell me how to program remote on seat alhambra 2010? with vvdi2 or vcds?
  5. The Following User Says Thank You to barho67 For This Useful Post:
    comizelu (19th June, 2019)
  6. #6140
    Apr 2016
    uk
    Quote Originally Posted by barho67 View Post
    Vcds
    09- central el.
    Choose remote adaptation
  7. The Following User Says Thank You to comizelu For This Useful Post:
    barho67 (19th June, 2019)
  8. #6141
    Apr 2016
    uk
    Quote Originally Posted by sdnatlst View Post
    Maybe you have the key that comes with a separate module to connect to bcm.. something like this?
    https://s.click.aliexpress.com/e/cgcR4Ng4
  9. #6142
    Sep 2010
    today make i key for vw polo 2017 MQB with VVDI2 everythink ok.costumer happy.
  10. The Following User Says Thank You to triak88 For This Useful Post:
    super jumbe (21st June, 2019)
  11. #6143
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by triak88 View Post
    spare?
    remonte?
  12. #6144
    Oct 2016
    France
    hi,can vvdi make immo off on audi edc17cp04? original ecu is brocken(water) so client want to make immo off on the ecu which he did buy, or meaby i can adapt ecu with vvdi2? but how to do?
  13. #6145
    Sep 2010
    spare remonte
  14. #6146
    super jumbe's Avatar
    Livingstone
    Last month customer rang for spare key on 2017 Polo I bottled out now this has been tested I will have a go any instruction you could add to this will appreciate.
  15. #6147
    Sep 2010
    first goto diagnostic which told you type of cluster then save EEprom and IMMO . make dealer key, reset cluster, add key by IMMO data,.Remote automatic work.
  16. The Following User Says Thank You to triak88 For This Useful Post:
    dooshan (21st June, 2019)
  17. #6148
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Part number key?
  18. #6149
    Sep 2010
    5g0 959 752
  19. The Following User Says Thank You to triak88 For This Useful Post:
    drugowaz (21st June, 2019)
  20. #6150
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Same as golf 7 ? No letter in end?
