Page 411 of 555 FirstFirst ... 311361401406407408409410411412413414415416421461511 ... LastLast
Results 6,151 to 6,165 of 8323
  1. #6151
    yugo45's Avatar
    Quote Originally Posted by barho67 View Post
    hi,can vvdi make immo off on audi edc17cp04? original ecu is brocken(water) so client want to make immo off on the ecu which he did buy, or meaby i can adapt ecu with vvdi2? but how to do?
    If is CAN protocol Immo off will work, If is UDS protocol , need to program it.
    For programing need to read Flash and eeprom, decript CS and Pin then use adopt control module option, or If you read dash , you can edit manually VIN, CS, MAC and Pin then save modded eeprom and write to ECU.
  2. The Following User Says Thank You to yugo45 For This Useful Post:
    barho67 (22nd June, 2019)
  3. #6152
    Apr 2016
    uk
    Audi A3 late 2016 spare key successful.
    Remote automatically works..
  4. The Following 2 Users Say Thank You to comizelu For This Useful Post:
    triak88 (1st July, 2019), yugo45 (24th June, 2019)
  5. #6153
    Sep 2016
    How can downgrade CAS.?
    Safety and correctly?
  6. #6154
    auto techniek's Avatar
    Mar 2017
    on bench of course with good power adapter
    make first backup if something goes wrong.
  7. The Following User Says Thank You to auto techniek For This Useful Post:
    lock66 (24th June, 2019)
  8. #6155
    sdnatlst's Avatar
    Aug 2011
    England
    What key are you talking about? 8e?
    If is remote 8e,id48,434mhz is for Audi A4 2005-2008.
    If is 4f with tp 8e in circuit,868mhz this is what you need.
    Remote cannot be programmed manually or by diagnostically.
    Just to check, do i click Generate Dealer Key, or generate OEM remote key, on the screen?
    I have 8e 868mhz key now
    1. read eeprom by obd, note down login and CS
    2. generate dealer key, select eeprom file
    3. enter CS and pin data, and select 2 keys, learn, and cycle keys, right?
    Tools owned -
  9. #6156
    Sep 2016
    Quote Originally Posted by sdnatlst View Post
    be sure that ezs isnt 9s12dg256 with SW =>2.10 otherwise pass job to dealer or take out ezs.
  10. The Following User Says Thank You to qeso705 For This Useful Post:
    p1et (24th June, 2019)
  11. #6157
    sdnatlst's Avatar
    Aug 2011
    England
    Quote Originally Posted by qeso705 View Post
    VVDI2 says only 2009, and onwards can use 256,
    This is 2006 car, so im hopefully it is the older one ?
    Tools owned -
  12. #6158
    p1et's Avatar
    Oct 2013
    VVDI2 show us SW version?
  13. #6159
    Apr 2016
    uk
    Never done one 2009+.I've done only -2009.
    I read data from ECU.
    What's wrong with this SW 2.10 ??what can happen? vvdi2 will not adapt keys on this one even if have cs and pin?
    I have to do a 2009 4his weekend probably..
  14. #6160
    Sep 2016
    Full cs is only in ezs. Read eeprom not work at 256 via obd2, read cs with working key make module dead.
  15. #6161
    Apr 2016
    uk
    On -2009 we don't need full cs,6bytes Is enough.
    On 2009+ we need 7bytes?
  16. #6162
    In EEP
    On 2005 to 2014 need 7bytes CS
  17. #6163
    Sep 2016
    2004-2015 need 12byte for transponder. Diffrence is only that on dg128 you can read rest from ezs when 6byte + pin is present or with working key. On 256 you cant do it at all via 6byte+pin and with working key you need be carefull as versions mentioned above can be dead after running this function.
  18. #6164
    yugo45's Avatar
    2.10 was problem with AVDI , never with VVDI. and by now both tools should read it with out problems.
  19. The Following 4 Users Say Thank You to yugo45 For This Useful Post:
    amigokola (6th July, 2019), comizelu (27th June, 2019), kronk92 (15th March, 2020), p1et (27th June, 2019)
  20. #6165
    Default 2006 BMW 325i CAS2 remote not working
    Hello folks
    so when i programmed the fob the way I always do cas2 with vvdi the car starts.
    but for some reason i can not get the remote function to work.
    made sure remote is 315mhz
    at the end of the process(see picture) vvdi states that "writing failed" but it starts the car
    any recomendations! should i directly write into the cas2?
    the key info is written in slot 6 and 2 by the way
