Page 413 of 553 FirstFirst ... 313363403408409410411412413414415416417418423463513 ... LastLast
Results 6,181 to 6,195 of 8287
  1. #6181
    auto techniek's Avatar
    Mar 2017
    with vcds under comfort module = adaptation
    I can also use Lonsdor next time.
    Use vcds?
    Vvdi2 is not the best tool for remote programming..
  2. #6182
    yugo45's Avatar
    Quote Originally Posted by khalilo_de View Post
    I tried with new key batterie with no success and the key was working before
    The problem is in vvdi2
    Envoyé de mon SM-G973F en utilisant Tapatalk
    I just did Kessy key week ago and worked fine with VVDI2 (Add one new and reprogram old, total 2 keys), so I can assure you that VVDI2 is not a problem.
  3. The Following User Says Thank You to yugo45 For This Useful Post:
    immoneard (4th July, 2019)
  4. #6183
    Mar 2017
    Slot key passat?
    When I press button te learn get message failed.
    Quote Originally Posted by yugo45 View Post
  5. #6184
    yugo45's Avatar
    Quote Originally Posted by auto techniek View Post
    Slot key passat?
    No, I was talking about VW Golf with Kessy system. Read post before this one.
    For your car go to 46-Confort , Adaptation Ch 00, Save.
    Adaptation Ch 01 put 1 in new value TEST , SAVE , then press unlock button on key , and remote will adopt. But this will work only on ID48 keys, if you have ID46 kessy keys , then key remote will program with key programing.
  6. The Following 3 Users Say Thank You to yugo45 For This Useful Post:
    auto techniek (4th July, 2019), immoneard (4th July, 2019), kronk92 (15th March, 2020)
  7. #6185
    Mar 2017
    I ve ID48 Key
    I wil try it.
  8. #6186
    Apr 2016
    uk
    Anyone had problems with golf Mk7 after key programming?
    I have tpms light on.tried to reset but the confirm button does not come on, instead an error came up, something like "not available".
    Tried to clear all DTC ,the same.
    Car was golf 2014 gti
    Any idea?
  9. #6187
    Maartinj's Avatar
    Nov 2010
    Any idea?
    not at all
    but what error you have ?
    TPMS perhaps show issue because cluster was "boot mode" so lost CAN connection ...but after reset should back to normal and DTC should be easy delete
  10. The Following User Says Thank You to Maartinj For This Useful Post:
    comizelu (5th July, 2019)
  11. #6188
    Apr 2016
    uk
    Quote Originally Posted by Maartinj View Post
    not at all
    I did a full scan with vcds and clear all errors.
    Than I tried to reset TPMS and had error "not available" instead of confirm button.
    I was reading on Ross tech forum that if retrofit a TPMS you need to drive the car for about one hour to activate it.
    I told customer to drive the car and let me know.
    Maybe lost coding??
    Will see how it goes...
  12. #6189
    pepi's Avatar
    It will go off ,this is common error when working with dash on golf7.
  13. The Following 2 Users Say Thank You to pepi For This Useful Post:
    comizelu (5th July, 2019), p1et (5th July, 2019)
  14. #6190
    sdnatlst's Avatar
    Aug 2011
    England
    Hi how is Q7 868 8e 2010 done when AKL ?
    Do I need to remove ezs if so how is that done and will I clip onto with vvdi prog or is it solder job
    Maybe vag helper save removing ezs?
    Tools owned -
  15. #6191
    drugowaz's Avatar
    Mar 2015
    Lithuania
    256 mcu. Need remove
  16. The Following User Says Thank You to drugowaz For This Useful Post:
    sdnatlst (5th July, 2019)
  17. #6192
    sdnatlst's Avatar
    Aug 2011
    England
    Clip on to read vvdi prog or solder job ?
    Not possible with vag helper ?
    Tools owned -
  18. #6193
    sdnatlst's Avatar
    Aug 2011
    England
    Tools owned -
  19. #6194
    sdnatlst's Avatar
    Aug 2011
    England
    CORRECTION - customer now told me actually its 57 plate, Q7.
    So does that mean i can do AKL OBD as it would be a 128 EZS or not?
    Tools owned -
  20. #6195
    drugowaz's Avatar
    Mar 2015
    Lithuania
    What clip your talking about. Need remove all steering rack,cut bolts, open elv read mcu in cirquit ant that program. 256mch bdm point on condensers super small ,not like 128mcu read easy.
    Q7 2010 will be 256 100%
  21. The Following User Says Thank You to drugowaz For This Useful Post:
    immoneard (6th July, 2019)
